There is a variety of techniques and equipment for astro stuff to avoid star trails, half a stop on the lens wont be a big difference (you would be better off with a fast prime like a 35mm f/1.8 (or the sigma f/1.4) or a 24mm f/1.8 that hopefully sigma releases soon).
To avoid trails the professional way (expensive) is to you a motorized tripod that rotates as the correct speed (computer controlled normally). Otherwise you can simply combine multiple exposures in software that does the alignment for you.
Saying that, if astro work was very important then the ability to get a wider aperture can certainly be useful.
