Battlefield 4 Thread ~ Server details in opening post ~
Running stock gtx 670's in sli, custom preset with everything on ultra, x4 msaa post aa off.
Frames, Time (ms), Min, Max, Avg
10568, 120000, 56, 139, 88.067
1477, 20951, 28, 103, 70.498
Plays pretty well, using the latest beta driver. Pretty hard to tell card usage, vram use etc as afterburner osd doesnt work.
I have to admit that I'm surprised by that performance. I'm running overclocked 680s on the same drivers and getting the same performance on Low/2xMSAA.
Can you show the CPU usage as well? it's now monitored in AB, cheers.
Max cpu use of 65%, 4770k at 4.5ghz, ram at 2133mhz 9-10-10-21 1T.
Gpu use maxed at 99% per card. Would be lower in sli with an i5 cpu.
What res you at Kiwi? My 670's are currently at stock. One is a very good clocker, (+130/+760) but the other is pretty poor. In benchmarks i run both at +80/+600 to allow for the weaker one.
All bound correctly. Its firing when I jump. LOL And jump is NOT bound to fire. Buggy as hell IMO.
All works fine in BF3...
This is happening to me too. Mine is all binded correctly. My gun only shoots when I jump or crouch or go prone?!
Also I don't think I can walk, it appears to be stuck on sprint.
I'm actually suprised how little difference there is between low and ultra. It might be that not everything is included in the beta of course.
I think theres something wrong with his settings its rendering some effects on low that aren't there with low settings - some of the ground decals for instance are just solid colored with actual low settings.
The difference is much more apparent close up also than in distant shots.
Lets hope they tweak it abit and give us more than one bloody map, laggy stuttering is bad enough but one map all day everyday is hardly testing im disappointed I may cancel my pre order if they don't fix it.
i5 3570k at 4.5ghz and msi gtx lightning 780 should not be having this issue :(
Hopefully well see another map. With the bf3 beta they eventually released caspian border after a few days.
Fairly usual with a beta (assuming they are actually half monitoring it to improve the game) to release one map and get some stats based on what people are doing then release another map to test out some of the info the stats are telling em.
i tried the newest ati betas and my performance was worse went back to last official ones which have been pretty much problemless.
gg kiwi :D
Don't know why people are getting mad at the visuals and performance for a beta :D :p Love the comments where people are rushing out to buy a new CPU, GPU etc. too :D :D :D
It was the exact same for bf3 beta, performance issues galore, final release with improved drivers ran much better
Same for visuals, none of the high res. textures etc. were included in the beta and thus final game looked much better.
Personally I think this is quite an old build as the textures and other things in lvlcaps etc. footage (that he got exclusively) looks much better than this beta.....
You need mantle capable GPU bro or you won't have teh horsepowers to run it properly.
Also 6 or 8 core AMD CPU to complement the mantles.
Also buy a nice vase to go on your mantle.
