- 22 Oct 2009
- Middlesex
Hi
I was hoping someone could help me with some calculations I need to do at work, figuring out how much energy someone uses on an Economy 7 electricity tariff. I've been trying to figure it out all day, but haven't got very far, and it's got people at work stumped too.
So a tariff could have 3 rates, the first two are calculated based on how much electricity someone uses during the day, and the third one is calculated based on how much they use at night. The first two rates are tiered, so that the first 720kWh they use is calculated at the first rate, and the remainder is calculated at the second rate.
So let's say someone spends £600 a year, and they use 45% of their electricity during the day, and 55% at night. I need to find out how much electricity they're using in total throughout the year, using these rates:
Tier 1 (day):
25.868 pence per kWh for the first 720kWh
Tier 2 (day):
17.661 pence per kWh for the remainder
Tier 3 (night):
6.123 pence per kWh
I know that they're using the max of 720kWh for the first tier, but I'm stuck trying to figure out how much they're using for the subsequent tiers. It seems like you need to know one before knowing the other.
Here's a spreadsheet that might explain better, if anyone wants to give this a go. I basically need to fill in the Usage column.
https://www.dropbox.com/s/jpo5898tjn1c375/Untitled 1.xlsx
Thanks for any help.
Tier 1 (day):
Tier 2 (day):
Tier 3 (night):
6.123 pence per kWh
