** AOC MONITORS NOW AVAILABLE & IN STOCK AT OcUK!! **
OcUK Staff
17 Oct 2002
OcUK HQ
Hi there
AOC are now designing some very nice monitors including high-end premium and gaming models, hence this decision to start stocking their brand on their higher-end models:-
AOC E2250SWDAK 21.5" Widescreen LED Monitor - Black @ £95.99 inc VAT
This model is characterised by the latest display technology with LED backlights, a top performance and a timelessly classic, black design. Due to high contrast and brightness values as well as a quick response time, the monitor renders even the fastest movie sequences fluently and razor-sharp. At its slimmest region, this elegant display, which sports hairline textures on the rear side as well as the base, is just 1.6 cm deep. Thanks to numerous features it is recommended for both office and home.
Specification:-
- Monitor Size: 21.5"
- Visible Screen Size: 54.6 cm
- Screen Format: 16:9
- Brightness: 250 (typ) cd/m² (typ)
- Contrast Ratio Dynamic: 20.000.000:1 (DCR)
- Contrast Ratio Typical: 1000:1
- Pixel / Dot / Pitch: 0.248 (H) x 0.248 (V)
- Display Area: 477.5 (H) x 268.5 (V)
- Viewing Angle: 170° /160° (CR 10)
- Response Time: 5 ms
- Maximum Resolution: 1920 x 1080@60 Hz
- Recommend Resolution: 1920 x 1080@60 Hz
- Colors: 16.7 M
- HDCP compatible: Yes
- Inputs: Analogue & DVI-D
- Dimensions (WxHxD): 511.18 x 379.95 x 190 mm
- Warranty: 3yr
Only £95.99 inc VAT.
ORDER NOW
AOC I2369VM 23" Widescreen LED IPS Monitor - Black/Silver @ £129.95 inc VAT
This Full HD display sets a new milestone in IPS display technology. It boasts a great design and offers extensive connectivity options, such as D-Sub, two HDMI connectors and a DisplayPort. The practical MHL interface even allows you to directly hook up your Android mobile devices to the monitor. IPS is known for vivid colours as well as high viewing angle stability. The competitively priced i2369Vm proves that this technology and high standard has become affordable to all. The display comes with a 250 cd/m² brightness, a dynamic contrast of 50,000,000:1 and a 6 ms response time for your ultimate viewing experience.
Specification:-
- Monitor Size: 23"
- Visible Screen Size: 58.4 cm
- Contrast Ratio Dynamic: 50.000.000:1 (DCR)
- Pixel / Dot / Pitch: 0.265 (H) x 0.265 (V)
- Display Area: 509.76 (H) x 286.74 (V)
- Viewing Angle: 178°/178° (CR 10)
- Response Time: 6 ms GtG
- Colors: 16.7 M
- Dimensions (WxHxD): 531.4 x 398 x 204
- Warranty: 3yr
Only £129.95 inc VAT.
ORDER NOW
AOC E2450SWDAK 24" Widescreen LED Monitor - Black @ £109.99 inc VAT
Specification:-
- Monitor Size: 23.6"
- Visible Screen Size: 59.9 cm
- Pixel / Dot / Pitch: 0.2715 (H) x 0.2715 (V)
- Display Area: 521.28 (H) x 293.32 (V)
- Viewing Angle: 170°/160° (CR 10)
- Colors: 16.7 M
- Inputs: Analogue, DVI-D
- Dimensions (WxHxD): 569.22 x 205 x 413.95 mm
- Warranty: 3yr
Only £109.99 inc VAT.
ORDER NOW
AOC G2460PQU 24" Widescreen 144Hz 1ms Gaming LED Monitor - Gunmetal @ £259.99 inc VAT
This display will make any gaming enthusiast´s heart beat faster: the stylish g2460Pqu will impress you with crystal-clear pictures. Enjoy fast-paced action sequences from the latest games or movies – crisp and blur-free due to an ultra-fast response time of just one millisecond and a refresh rate of 144 Hz. The strong typical contrast (1000:1) and high brightness (350 cd/m²) provide brilliant images. This gamers´ dream-come-true sports numerous connectivity options, such as D-Sub, DVI Dual Link, HDMI, DisplayPort and an integrated USB hub. These enable you to comfortably plug in several devices at the same time and display hi-res content on the large 61 cm (24") screen. Also on board: an integrated USB hub with 4 ports, including a fast-charge USB port for mobile devices. In addition, the Full HD display is equipped with LED backlights, making it particularly economical despite its great performance.
Specification:-
- Monitor Size: 24"
- Visible Screen Size: 61 cm
- Brightness: 350 cd/m² (typ)
- Contrast Ratio Dynamic: 80.000.000:1
- Pixel / Dot / Pitch: 0.276 (H) x 0.276 (V)
- Display Area: 531.36 (H) x 298.89 (V)
- Response Time: Up to 1 ms GtG
- Maximum Resolution: 1920 x 1080@144 Hz
- Recommend Resolution: 1920 x 1080@144 Hz
- Colors: 16.7 M
- HDCP compatible: yes
- Inputs: Analogue, DVI-D, HDMI & DisplayPort
- Dimensions (WxHxD): 565.4 x 393.6 (+130) x 244.58 mm
- Warranty: 3yr
Only £259.99 inc VAT.
ORDER NOW
AOC Q2963PM 29" Professional Super-Wide LED Multimedia Monitor - Gunmetal @ £359.99 inc VAT
AOC’s Q2963PM greatly enhances your productivity and experience; work and leisure won’t be the same with features like the ultrawide cinematic screen, screen-splitter function, and dual link-up. Whether it’s for viewing multiple documents, a more immersive movie and gaming experience, or multitasking simplicity, the 29” Ultrawide 21:9 screen monitor gives you what you need.
The AOC 29” UltraWide features an LED Backlit screen that offers brilliant color and ultra clear images. The full HD 1080P Resolution, with 50,000,000:1 contrast ratio and response time of 6ms, creates superior picture sharpness and the In Plane Switching (IPS) Panel allows you to view your spreadsheets or weekend movies from virtually any angle without compromising color uniformity.
The UltraWide is available for multiple full sized applications as an upgrade to dual monitor settings. Enjoy dual monitor productivity on a single screen. The vast panoramic screen is easy on the eyes, and with the screen-splitter function, multitasking has never been so simple.
The AOC 29” UltraWide screen and equipped dual 3 Watt enclosed speakers deliver a more awesome immersive experience for your favorite movies or games. The narrow bezel frame offers a sleek cinema-like screen experience.
The AOC 29” UltraWide’s connectivity is ultra-useful. The HDMI Connections carry high definition picture and sound in one easy cable. The HDMI with MHL allow you to connect your smartphone easily without a network connection. You can stream videos from your phone on to the monitor screen while charging your mobile device at the same time.
The PIP/PBP Hardware Calibration Ready (Dual Link Up) allow two devices to be viewed on the monitor simultaneously. The DisplayPort connection allows you to connect several monitors to your notebook with one simple cable.
The AOC 29” UltraWide is EnergyStar qualified, which means it uses about 30% less energy than standard units. Plus, it has no arsenic in the glass, mercury-free LED, and no BFR/PVC Laminates. It also qualifies for the latest standards such as TCO and Energy Star.
Features:-
- Panoramic screen with screen-splitter function for multitasking ease
- Cinematic Screen with 21:9 Aspect Ratio
- WFHD maximum resolution of 2560 x 1080 @60Hz
- PBP or PIP multitasking function for enjoying an image from two sources at once
- Multimedia connectors for VGA, DVI-D with HDCP, HDMI (MHL), DisplayPort
- Mobile High-Definition Link (MHL) to connect and charge the phone
- IPS Panel with full HD 1080P and an LED backlit screen
Specification:-
- Viewable Image Size: 29" (21:9)
- Brightness (typical): 300 cd/m2
- Contrast Ratio: 50000000:1
- Response Time: 5ms
- Optimum Resolution: 2560 x 1080 @ 60Hz
- Colors Supported: 16 Million
- Inputs: RGB D-Sub, DVI-D, HDMI & DisplayPort
- Built-in Stereo Speakers: Yes / 6W
- ENERGY STAR ? Compliant: Yes
- EPEAT Rated: Yes
- Dimensions (WxHxD): 713.57 x 387.91 x 211.99 mm
- Warranty: 3yr
Only £359.99 inc VAT.
ORDER NOW
That's the lowest priced 29" Super-Wide yet!!!! :D :D :D
Quite tempted to get 3 of the AOC G2460PQU 24" monitors, although seems an expensive way to get around AMDs reluctance to include multiple DVI sockets (except on the 1 (?) new card) and the fact they wont let you use outputs from multiple cards when in Crossfire!
Who chooses the pictures for these monitors? :P
It's not that I mind seeing Denise Milani?, but a bit NSFW almost..
Very tempted by that 23" IPS one myself ;) How is it for gaming compared to other monitors of a similar price? (non IPS)
Would like to see some reviews on the 144 hz model had an old aoc CRT screen year back was pretty reliable for what it was
Seriously considering that 29". In theory will it work in kind of a surround setup with another 24" slapped to the side? As I'll be keeping my 24" 120hz for fps/3d. So would be nice to experience surround as well :)
I've recently got a AOC monitor and the build / image quality is amazing. I'd highly recommend them. :D
It is why we are doing them again, a few years ago they are what we would call a budget brand. But the new models seem to be targeting the enthusiast and premium user a lot more, as the quality has certainly improved. :)
Ive done some research into the g2460Pqu and ive come to the conclusion it needs to be cheaper.
Compared to the XL2411T it has no 3d or lightboost support its 144hz input lag is a lot slower than the XL 13ms to 2ms yes it has slightly better colour representation but it uses the same panel so the variations are just firmware based and therefore small and lets be honest we all know that tns dont hold a candle to ips screens anyway, it also has some usb ports, I'm not sure thats a selling point though as I havnt seen a system short on them in years.
Long and short I cant see anyone taking this over the XL at the same price now if this was priced around the 200-210 mark I could see it selling as a cheaper alternative however Im sure thats probably out of ocuks hands, these are gaming screens and not having the gaming features like lightboost and 3d put them into a separate category somewhere between 60hz screen and 120/144hz screens
The 23" IPS model is very good quality in terms on image etc, the only down fall is the stand is a little wobbly.
