- 3 Aug 2008
- Bath, England
rubbish app
Any reasons?
1
Poor UI
2.
Buggy and sometimes doesn't reset the stats for you when you unplug it(mine currently says my device has been uncharged/unplugged for 5 days. Yea i wish my phone can last 5 days
3.
Most information makes no sense on what is draining your battery such xmb_wakelock? qcril_fd? msn_hsic_host? O and i am not making that up. That is what stats are shown on my phone.
1.
the UI is fine.
2.
never had a single problem with it. i suspect PEBKAC.
3.
you not heard of google?
It's a functional app it's not been designed to be pretty and spoon feed you information, it's like a lot of the anti malware programs you can get for pcs that just reel off a massive log file of what might as well be written in martian if you don't know what you're looking for.
yup i heard of google which makes this app half arsed if people have to google the definitions.
O and i have googled some of these definitions before and came back empty handed.
It explains the UI, it's been built as a tool not to look pretty.
I've never experienced any buggyness on my S3,S4 or N7
then look harder.
everthing i've needed to look up off BBS i've found and got a decent slab of info on.
as i said before, PEBKAC
Could never found out what was draining my One X and desire.
1
Poor UI
2.
3.
The biggest drain of this battery is by far using Google Maps. Holy **** this drains the battery by the end of an hour and half journey.![]()
Probably has something to do with the screen being on and GPS+GSM data being used?![]()
