Crossfired 7970s and PCI-E sound card-potential performance loss?
12 Aug 2005
Orpington.
It wil take x4 lanes from your second GPU in the 3rd PCie slot, meaning you'll be running x8/x4 crossfire, which should be fine considering it's running at PCIe 3.0 depending on the resolution you're playing on.
How about the very bottom orange PCIe slot? Unlike the first three it's controlled via the chipset instead of the CPU, so no lanes will be stolen from your GPUs.
