If the latter then the absolute biggest pain in the arse is getting inpa etc to talk properly with windows 7 - I've managed it without a virtual machine but it took me so long to get it sorted ( and it still isn't quite right) I would have been better just putting an xp partition on for it and retrospectively fixing the boot loader
You shouldn't need the BMW diag port, instead the OBDII port under the dash near the pedals is the port you want. You can use the under bonnet port but there is no real reason to when you have the interior one available.
E: there is a good kit available that a few on here have bought from but I can't remember the site, gives all the software you need, cables etc.
Worked fine for me on my Windows 7 laptop, got it all running fully, DIS & INPA both ran well, just my E30 doesn't have the ability to be read, a multimeter is a better diag tool.![]()
[TW]Fox;25064954 said:The early e46 does not have the port under the dash.
