Best Iphone 5/5s in car kit
Permabanned
21 Nov 2010
Newton Aycliffe
This is something i always struggled to find for iPhone, best i could find was the brodit holders but they weren't great.
HTC do their own in car kit and it's great.
Any suggestions on the best in car kit for a 5s? Not bothered about audio integration due to having bluetooth, but must be able to have a charger lead attached fairly inconspicuously and good for satnav use e.g. rotatable.
I have a Brodit based one for my iPhone 4.
I'm not sure it will fit a 5 though as the one I have has an extra bit at the top to keep it secure. If it doesn't fit a 5S, I will certainly purchase a new one to make it compatible.
Thanks.
I have used brodit in the past and found if you want to rotate the phone for satnav a lot the screw gets loose and the holder rotates freely. Has no-one else found that?
Main thing is having one that a charger sits in nicely and you can just slide the phone into it while being rotatable.
I currently use a Brodit Holder / ProClip in my car , mines for the iphone 4 , but i have recently upgraded to the 5S and it still holds it without a problem.
However i got this on order at the moment
http://www.kenu.com/products/airframe
Seems to be a little less bulky than the Brodit solution and a heck of a lot cheaper.
