- 12 Jun 2006
Building a new rig and I have decided on these parts so far
4770k
Gigabyte Z87X UD4H
Noctua DH14
I need low profile RAM so they can fit with the cooler. Looking for 8GB (2x4GB sticks). Maybe some taller sticks can fit but I will have to check compatibility on the Noctua website first.
What would you recommend? I plan on OCing the CPU as much as I can so they must be able to perform well. The rig will be for gaming. Budget wise, I don't want to spend too much, probably around £70.
4770k
Gigabyte Z87X UD4H
Noctua DH14
