Anything better than a Silver Arrow for the money?
18 Oct 2002
Kent
Just wondering if anyone thinks there is a better cooler than the Silver Arrow for less than £60 and if so, what is it?
Thanks
The Silver arrow is slightly better, as is the Phanteks TC14.
The performance differences are so minor that you're better off making your decision based on what fits and which one you like the look of most.
The Phanteks looks to be a tenner or so more expensive unless im looking at the wrong ones?
My Case is pretty huge and being windowless I dont care much for aesthetics.
SilverArrow SB-E SE has black/white TY-145 fans 74cfm/1300rpm £59.99
http://www.overclockers.co.uk/showproduct.php?prodid=HS-101-TR
TY-145 fan is black/white version of TY-141, the front fan on Silver Arrow SB-E
http://www.overclockers.co.uk/showproduct.php?prodid=HS-078-TR
Silver Arrow SB-E Extreme has TY-143 red/orange fans 130cfm/2500rpm £53.99
http://www.overclockers.co.uk/showproduct.php?prodid=HS-099-TR
TY-143 fan
http://www.overclockers.co.uk/showproduct.php?prodid=HS-100-TR
The SA SB-E Extreme with TY-143 fans will perform and sound the same as SA SB-E or SA SB-E SE below 1300rpm. Advantage is if you want more cooler and can put up with the added noise it's available. It is also the cheapest.
I have SA SB-E SE and SA SB-E Extreme. I also have PH-TC14PE and have ran TY-140, TY-143, TY-147, PH-F140TS and PH-F140HP fans. Up to 1200-1300rpm they are very similar is performance and sound.
