Hi,
I've just put a deposit down on an E46 M3 after waiting for a decent one to turn up in the NZ market. It's got FBSH and the seller is putting it through its inspection II as part of the deal. The SMG pump was changed 10,000kms ago so that's sweet - the only worry now is the VANOS, so i'm looking at getting some preventative maintenance sorted out while the engine is in bits. My understanding is that the parts to change will be;
Vanos bolts + loctite
Biesian seal kit
Exhaust hub / tab
Vanos filter
All the above are relatively cheap from what I can see. Is there anything else i've missed though?
Any help appreciated.
Cheers
Biesian seal kit
Exhaust hub / tab
Vanos filter
Cheers
