Sorry, this is probably a really stupid question, but does network cable carry electricity voltage which could cause a fire risk if installed under carpet?
I know carpet fitters won't install cable under the carpet, but not sure if that is specifically to do with network cabling or not.
I have no other option sadly, but can at least run it parallel with the carpet edging frames and under a couple of thresholds to avoid constant standing on it or rubbing, but just want to be sure in case it does eventually give wear apart.
