** ALL OcUK LAPTOPS IN STOCK & PRICE DROP!! **
OcUK Staff
17 Oct 2002
OcUK HQ
Hi there
Great news all the components we use to build our own laptops are now in stock, we've also reduced the prices slightly and added the following new options:-
  • Intel i5-4200M Dual Core Haswell with Hyperthreading
  • Kingston HyperX Memory
  • Samsung 840 EVO Range
  • French, German and USA Keyboard layout/languages
  • Killer WiFi Cards
OcUK Piranha Gamer W230ST 13.3" LED Full HD Intel Haswell Processor, 1600MHz DDR3, SSD + HDD, NVIDIA GeForce GTX 765M 2GB GDDR5 Graphics Card - Windows Laptop - Black @ £740.90 inc VAT
Want a powerful gaming laptop but also need it to be mobile, small and lightweight? Sporting the NVIDIA GTX 765M, the OcUK Piranha delivers and is one of the most powerful gaming laptops under 14" in size. Only 31mm thin and weighing only 2kg, the 13.3" OcUK Piranha laptop delivers the perfect balance of gaming performance and portability at an affordable price.
Also because here at OcUK we do extensive R&D and in house testing, we remove all the factory standard thermal compound/TIM and replace with high quality premium thermal compound that we use in our extreme overclocked PC's. You may ask why do we do this? Well it is simple by doing so the under-load temperatures of the CPU and graphics can decrease by as much as 20c under heavy load situations. So by doing this we get several advantages, cooler running, less chance of thermal throttling, fans run slower and hence quieter, plus of course the lifespan of the product is extended. This service is mandatory on all the laptops we build and we don't charge extra for it unlike some of our competitors. So when buying from OcUK you can be sure you laptop won't thermally throttle its performance or over-heat, further adding to the buying confidence.
Small in size and big in features, the OcUK Piranha features a True HD LED backlit LCD display with a native resolution of 1920x1080, really bringing games and blu-ray movies to life. Sound is superb through the ONKYO dual stereo speakers with audio SoundBlaster Cinema technology delivering clear, loud and stunning audio reproduction.
Under the hood, there are few options for processor, the Intel i7-4700MQ quad core processor with a base clock rates at 2.4GHZ (up to 3.4GHZ via Turbo Boost technology), Intel i7-4702MQ quad core (2.2 to 3.2GHz) processor, Intel i7-4800MQ quad core (2.7 to 3.7GHz) processor or up to Intel i7-4900MQ quad core (2.8 to 3.8GHz) processor. Inside, the new Intel HM87 chipset supports up to 16GB 1600Mhz DDR3 SDRAM, providing ultimate power and fast performance for hard gaming sessions.
The OcUK Piranha Gaming laptop comes with a new rigid high quality material for construction and a classic design. On the left side, there are USB port, audio jack and microphone jack, while on the other side, you will find three USB 3.0 port, VGA port, RJ 45 for Ethernet, HDMI output port with HDCP support and multimedia card reader slot with supports SD, Mini-SD, RSMMC, SDHC, MMC, SDXC, MS Pro, MSand MS Duo formats. For connectivity it includes 10/100/1000Mb Base-TX Ethernet LAN, Bluetooth 4.0 and Intel Centrino Advanced-N 6235 AGN wireless LAN, with other wireless options that can be selected from the drop downs.
Like other Intel Haswell machines, the newest OcUK Piranha Gamer 13.3 inch gaming laptop also comes with a Intel Anti-Theft, Intel Rapid Start and Intel Smart Response technology. Yeah, this is a great laptop that offers ultimate graphics performance and portability.
Our recommended specification for gaming is Intel 4700MQ processor, 8GB of 1600MHz RAM, 60GB mSATA SSD Boot drive and 500GB or larger secondary drive. This laptop can take upto 2x mSATA drives and 2.5" laptop HDD. In common with smaller laptops there is no built-in ODD drive, but an external USB2.0/USB3.0 external ODD drive will work fine.
Specification:-
- Operating System: Choose from the drop down options!
- Display: 13.3" SuperBright LED True HD Matte Display (1920x1080 Resolution)
- Graphics: NVIDIA GeForce GTX 765M 2048MB GDDR5
- Storage: Choose from the drop down options!
- Sound Blaster HD Audio
- Mic Noise Suppression
- Dolby Home Theatre®
- 3W THX Stereo Speakers (2W x 4)
- 2 megapixel Webcam
- Processor: Intel® Core™ i7 4th Generation Haswell Processor - Choose exact model from drop down options!
- Memory: 4GB DDR3 System Memory at 1600MHz (4GB x 1) OR choose 8/16GB DDR3 Options
- Main Chipset: Intel HM87
- Communication: 10 / 100 / 1000 Gigabit Ethernet LAN,Wireless LAN, Widi Support
- WiFi Options: Choose from drop down menu
- 1x HDMI Port
- 1x VGA Port
- 3x USB3.0 Ports
- 1x USB2.0 Port
- 1x DC IN
- 1x RJ-45 Jack
- Kensington Lock: YES
- Full Range AC adapter, AC in 100~240V, 50~60Hz, DC output 19.5V, 11.8A, 230W
- Removable 6 cells Smart Lithium-Ion battery pack
- Dimensions: 330 (W)x227 (D)x 31 (H)mm
- 2Kg,including ODD and Battery
- 9in1 Card Reader
- 2yr Warranty (1yr Parts, 2yr Labour)
Service Package
- Full 24 Month collect and return warranty (12 month on parts)
- Each specification is assembled from handpicked components for compatibility and stability
- Telephone, web note and forum technical support
Is this Notebook for You?
Immense performance, powerful graphics and sleek hardware all combine to create the "OcUK Piranha Gamer W230ST, perfect for the gaming enthusiast on the move.
Note - If you would like to make a small change to the specification call our sales team on 0871 200 5052 and they will be happy to help.
* No OS systems are fully tested with the same extensive methods as systems chosen with an operating system. Including tests such as CPU, memory and GFX stress tests. All no OS systems are formatted completely before shipping.
*Please allow between 48 and 96 hours for your system to be built and configured. This may take longer during busier periods. You can choose from the drop down options to jump the queue by selecting one of our Fast Track options. If your choosing the 24hr next day service, to get the laptop delivered next working day you need to order pre 10:30am to give us enough time to build, test and get your laptop shipped out, otherwise you will get it the following day.
From £740.90 inc VAT.
ORDER NOW
OcUK Gamer W350STQ 15.6" LED Full HD Intel Haswell Processor, 1600MHz DDR3, SSD + HDD, NVIDIA GTX 765M 2GB GDDR5 Graphics Card - Windows Laptop - Cosmic Grey @ £778.90 inc VAT
For gamers the OcUK Gamer W350STQ is the perfect choice. There is no more powerful or better constructed option, with the latest 4th generation (Haswell) Intel Core I7 Processor there is no shortage of power and for those who only demand the most powerful, we can construct the OcUK Gamer W350STQ with an Intel I7 4900MQ processor too. Though our own in house testing shows the best bang for buck performance comes from the Intel Core I7 4702MQ & 4700MQ processors, so we highly recommend these when choosing a processor option.
This chassis uses the absolute very latest in technology such as SATA3, USB3.0, Bluetooth, WiFi but the most impressive of all is the fact this system feature an NVIDIA GTX 765M with 2GB of GDDR5 dedicated memory for absolutely blistering performance. With NVIDIA Optimus technology means you can game on move whilst still maintaining respectable battery life.
With a LED backlit 15.6" screen with True HD (1920x1080) resolution games have never looked so good on the go or ran so smooth due to the power of the NVIDIA GTX 765M onboard graphics. The OcUK Gamer W350STQ features high quality THX speakers with Sound Blaster cinema technology for the ultimate gaming experience.
For memory we only use the highest performance and most reliable for laptops, which is Corsair Vengeance which is set to run at 1600MHz with T1 memory timings resulting in absolute instant response. 8GB is the default choice which is more than adequate for all task and gaming, we only recommend 16GB kit if your also doing a lot of photography work or heavy multi-tasking. Corsair Vengeance 1600MHz will extract the very best performance from the OcUK Gamer W370ST causing zero bottlenecks in the system.
For hard drive options, we recommend the primary drive as an SSD drive, this means from point of pressing power on your should be at the Windows 8 Desktop in approx 10 seconds and with an SSD applications and games load more or less instantly. Of course if you preferre capacity you can choose a large capacity HDD or a Hybrid drive too. Our recommendation is to select an SSD for the primary drive along with a HDD as the secondary drive for storage.
When you buy a Overclockers UK system/laptop the only software you’ll find is your choice of operating system. We guarantee that there will be no third party apps, useless bloatware or unnecessary trial software, to keep your machine running at peak performance from the start. We also only install the latest drivers which are proven to provide maximum performance when gaming.
Specification:-
- Display: 15.6" SuperBright LED True HD Display (1920x1080 Resolution)
- Graphics: NVIDIA GTX 765M 2048MB GDDR5 with NVIDIA Optimus technology
- Optical: Choose from the drop down options!
- 4W THX Stereo Speakers (2W x 4)
- 1x HDMI Port
- 2x USB3.0 Ports
- 1x USB2.0 Port
- 1x E-SATA
- 1x VGA
- 1x DC IN
- 1x RJ-45 Jack
- 8 Cell Smart Lithium-ION Battery
- 9in1 Card Reader
Service Package
Immense performance, powerful graphics and sleek hardware all combine to create the "OcUK Gamer W350STQ", perfect for the gaming enthusiast.
From £778.90 inc VAT.
ORDER NOW
OcUK Gamer W370ST 17.3" LED Full HD Intel Haswell Processor, 1600MHz DDR3, SSD + HDD, NVIDIA GTX 765M 2GB GDDR5 Graphics Card - Windows Laptop - Cosmic Grey @ £808.90 inc VAT
For gamers the OcUK Gamer W370ST is the perfect choice. There is no more powerful or better constructed option, with the latest 4th generation (Haswell) Intel Core I7 Processor there is no shortage of power and for those who only demand the most powerful, we can construct the OcUK Gamer W370ST with an Intel I7 Extreme processor too. Though our own in house testing shows the best bang for buck performance comes from the Intel Core I7 4702MQ & 4700MQ processors, so we highly recommend these when choosing a processor option.
With a LED backlit 17.3" screen with True HD (1920x1080) resolution games have never looked so good on the go or ran so smooth due to the power of the NVIDIA GTX 765M onboard graphics. The OcUK Gamer W370ST features high quality THX speakers with Sound Blaster cinema technology for the ultimate gaming experience.
Specification:-
- Display: 17.3" SuperBright LED True HD Display (1920x1080 Resolution)
- 1x HDMI Port
- 2x USB3.0 Ports
- 1x USB2.0 Port
- 1x E-SATA
- 1x VGA
- 1x DC IN
- 1x RJ-45 Jack
- 9in1 Card Reader
Service Package
Immense performance, powerful graphics and sleek hardware all combine to create the "OcUK Gamer W370ST", perfect for the gaming enthusiast.
From £808.90 inc VAT.
ORDER NOW
OcUK Hardcore Gamer P157SM 15.6" LED Full HD Intel Haswell Processor, 1600MHz DDR3, SSD + HDD, ATI Radeon HD 8970M 4GB GDDR5 Graphics Card - Windows Laptop - Black @ £1058.89 inc VAT
For hardcore gamers who want the best in mobile gaming, look no further than the OcUK Hardcore Gamer P157SM. There is no more powerful or better constructed option, with the latest 4th generation (Haswell) Intel Core I7 Processor there is no shortage of power and for those who only demand the most powerful, we can construct the OcUK Hardcore Gamer P157SM with an Intel I7 Extreme processor too. Though our own in house testing shows the best bang for buck performance comes from the Intel Core I7 4800MQ & 4700MQ processors, so we highly recommend these when choosing a processor option.
This chassis uses the absolute very latest in technology such as SATA3, USB3.0, Bluetooth, WiFi but the most impressive of all is the fact this system features an ATI Radeon HD 8970M with 4GB of GDDR5 dedicated memory for absolutely blistering performance. With so much video memory and such horsepower you can even output to a 30" monitor and still have great gaming performance or run a multi-monitor setup.
With an LED backlit 15.6" screen with True HD (1920x1080) resolution games have never looked so good on the go or ran so smooth due to the power of the ATI HD 8970M's onboard graphics. The OcUK Hardcore Gamer P157SM features high quality THX speakers with Sound Blaster cinema technology for the ultimate gaming experience.
For memory we only use the highest performance and most reliable for laptops, which is Corsair Vengeance which is set to run at 1600MHz with T1 memory timings resulting in absolute instant response. 8GB is the default choice which is more than adequate for all task and gaming, we only recommend 16GB kit if your also doing a lot of photography work or heavy multi-tasking. Corsair Vengeance 1600MHz will extract the very best performance from the OcUK Hardcore Gamer P157SM causing zero bottlenecks in the system.
Specification:-
- Graphics: AMD / ATI Radeon HD 8970M 4096MB GDDR5
- Illustrator touchpad (glows when used)
- 1x HDMI Port
- 1x DisplayPort
- 1x Mini-DisplayPort
- 3x USB3.0 Ports
- 1x USB2.0 Port
- 1x Mini IEEE 1394a port
- 1x eSATA Port (USB 3.0 Combo)
- 1x DC IN
- 1x RJ-45 Jack
- Removable 8 cells Smart Lithium-Ion battery pack, 76.96WH
- Battery life: 300 minutes (with UMA mode, 76.96WH Battery)
- Dimensions: 414 (W)x286 (D)x 25.3~46.1 (H)mm
- 4.1Kg,including ODD and 76.96WH Battery
- 9in1 Card Reader
Service Package
Immense performance, powerful graphics and sleek hardware all combine to create the "OcUK Hardcore Gamer P177SM, perfect for the gaming enthusiast.
From £1058.89 inc VAT.
ORDER NOW
OcUK Hardcore Gamer P177SM 17.3" LED Full HD Intel Haswell Processor, 1600MHz DDR3, SSD + HDD, ATI Radeon HD 8970M 4GB GDDR5 Graphics Card - Windows Laptop - Black @ £1118.89 inc VAT
For hardcore gamers who want the best in mobile gaming, look no further than the OcUK Hardcore Gamer P177SM. There is no more powerful or better constructed option, with the latest 4th generation (Haswell) Intel Core I7 Processor there is no shortage of power and for those who only demand the most powerful, we can construct the OcUK Hardcore Gamer P177SM with an Intel I7 Extreme processor too. Though our own in house testing shows the best bang for buck performance comes from the Intel Core I7 4800MQ & 4700MQ processors, so we highly recommend these when choosing a processor option.
With an LED backlit 17.3" screen with True HD (1920x1080) resolution games have never looked so good on the go or ran so smooth due to the power of the ATI HD 8970M's onboard graphics. The OcUK Hardcore Gamer P177SM features high quality THX speakers with Sound Blaster cinema technology for the ultimate gaming experience.
For memory we only use the highest performance and most reliable for laptops, which is Corsair Vengeance which is set to run at 1600MHz with T1 memory timings resulting in absolute instant response. 8GB is the default choice which is more than adequate for all task and gaming, we only recommend 16GB kit if your also doing a lot of photography work or heavy multi-tasking. Corsair Vengeance 1600MHz will extract the very best performance from the OcUK Hardcore Gamer P177SM causing zero bottlenecks in the system.
Specification:-
- 1x HDMI Port
- 1x DisplayPort
- 3x USB3.0 Ports
- 1x USB2.0 Port
- 1x DC IN
- 1x RJ-45 Jack
- 9in1 Card Reader
Service Package
From £1118.89 inc VAT.
ORDER NOW
OcUK Hardcore Gamer P150SM 15.6" LED Full HD Intel Haswell Processor, 1600MHz DDR3, SSD + HDD, NVIDIA GeForce GTX 770M 3GB GDDR5 Graphics Card - Windows Laptop - Black @ £1022.89 inc VAT
For hardcore gamers who want the best in mobile gaming, look no further than the OcUK Hardcore Gamer P150SM. There is no more powerful or better constructed option, with the latest 4th generation (Haswell) Intel Core I7 Processor there is no shortage of power and for those who only demand the most powerful, we can construct the OcUK Hardcore Gamer P150SM with an Intel I7 Extreme processor too. Though our own in house testing shows the best bang for buck performance comes from the Intel Core I7 4800MQ & 4700MQ processors, so we highly recommend these when choosing a processor option.
This chassis uses the absolute very latest in technology such as SATA3, USB3.0, Bluetooth, WiFi but the most impressive of all is the fact this system features an NVIDIA GeForce GTX 770M with 3GB of GDDR5 dedicated memory for absolutely blistering performance. With so much video memory and such horsepower you can even output to a 30" monitor and still have great gaming performance or run a multi-monitor setup.
With an LED backlit 15.6" screen with True HD (1920x1080) resolution games have never looked so good on the go or ran so smooth due to the power of the NVIDIA GeForce GTX 770M onboard graphics. The OcUK Hardcore Gamer P150SM features high quality THX speakers with Sound Blaster cinema technology for the ultimate gaming experience.
For memory we only use the highest performance and most reliable for laptops, which is Corsair Vengeance which is set to run at 1600MHz with T1 memory timings resulting in absolute instant response. 8GB is the default choice which is more than adequate for all task and gaming, we only recommend 16GB kit if your also doing a lot of photography work or heavy multi-tasking. Corsair Vengeance 1600MHz will extract the very best performance from the OcUK Hardcore Gamer P170SM causing zero bottlenecks in the system.
Specification:-
- Graphics: NVIDIA GeForce GTX 770M 3072MB GDDR5
- 1x HDMI Port
- 1x DisplayPort
- 3x USB3.0 Ports
- 1x USB2.0 Port
- 1x DC IN
- 1x RJ-45 Jack
- 9in1 Card Reader
Service Package
Immense performance, powerful graphics and sleek hardware all combine to create the "OcUK Hardcore Gamer P150SM, perfect for the gaming enthusiast.
From £1022.89 inc VAT.
ORDER NOW
OcUK Hardcore Gamer P170SM 17.3" LED Full HD Intel Haswell Processor, 1600MHz DDR3, SSD + HDD, NVIDIA GeForce GTX 770M 3GB GDDR5 Graphics Card - Windows Laptop - Black @ £1078.90 inc VAT
For hardcore gamers who want the best in mobile gaming, look no further than the OcUK Hardcore Gamer P170SM. There is no more powerful or better constructed option, with the latest 4th generation (Haswell) Intel Core I7 Processor there is no shortage of power and for those who only demand the most powerful, we can construct the OcUK Hardcore Gamer P170SM with an Intel I7 Extreme processor too. Though our own in house testing shows the best bang for buck performance comes from the Intel Core I7 4800MQ & 4700MQ processors, so we highly recommend these when choosing a processor option.
With an LED backlit 17.3" screen with True HD (1920x1080) resolution games have never looked so good on the go or ran so smooth due to the power of the NVIDIA GeForce GTX 770M onboard graphics. The OcUK Hardcore Gamer P170SM features high quality THX speakers with Sound Blaster cinema technology for the ultimate gaming experience.
Specification:-
- 1x HDMI Port
- 1x DisplayPort
- 3x USB3.0 Ports
- 1x USB2.0 Port
- 1x DC IN
- 1x RJ-45 Jack
- 9in1 Card Reader
Service Package
Immense performance, powerful graphics and sleek hardware all combine to create the "OcUK Hardcore Gamer P170SM, perfect for the gaming enthusiast.
From £1078.90 inc VAT.
ORDER NOW
OcUK Hardcore Gamer P150SM 15.6" LED Full HD Intel Haswell Processor, 1600MHz DDR3, SSD + HDD, NVIDIA GeForce GTX 780M 4GB GDDR5 Graphics Card - Windows Laptop - Black @ £1,298.89 inc VAT
This chassis uses the absolute very latest in technology such as SATA3, USB3.0, Bluetooth, WiFi but the most impressive of all is the fact this system features an NVIDIA GeForce GTX 780M with 4GB of GDDR5 dedicated memory for absolutely blistering performance. With so much video memory and such horsepower you can even output to a 30" monitor and still have great gaming performance or run a multi-monitor setup.
With an LED backlit 15.6" screen with True HD (1920x1080) resolution games have never looked so good on the go or ran so smooth due to the power of the NVIDIA GeForce GTX 780M onboard graphics. The OcUK Hardcore Gamer P150SM features high quality THX speakers with Sound Blaster cinema technology for the ultimate gaming experience.
Specification:-
- Graphics: NVIDIA GeForce GTX 780M 4096MB GDDR5
- 1x HDMI Port
- 1x DisplayPort
- 3x USB3.0 Ports
- 1x USB2.0 Port
- 1x DC IN
- 1x RJ-45 Jack
- 9in1 Card Reader
Service Package
From £1,298.89 inc VAT.
ORDER NOW
OcUK Hardcore Gamer P170SM 17.3" LED Full HD Intel Haswell Processor, 1600MHz DDR3, SSD + HDD, NVIDIA GeForce GTX 780M 4GB GDDR5 Graphics Card - Windows Laptop - Black @ £1,358.89 inc VAT
With an LED backlit 17.3" screen with True HD (1920x1080) resolution games have never looked so good on the go or ran so smooth due to the power of the NVIDIA GeForce GTX 780M onboard graphics. The OcUK Hardcore Gamer P170SM features high quality THX speakers with Sound Blaster cinema technology for the ultimate gaming experience.
Specification:-
- 1x HDMI Port
- 1x DisplayPort
- 3x USB3.0 Ports
- 1x USB2.0 Port
- 1x DC IN
- 1x RJ-45 Jack
- 9in1 Card Reader
Service Package
From £1,358.89 inc VAT.
ORDER NOW
OcUK Ultimate Gamer P370SM 17.3" LED Full HD Intel Haswell Processor, 1600MHz DDR3, SSD + HDD, ATI Radeon HD 8970M 4GB GDDR5 Crossfire Graphics Cards - Windows Laptop - Black @ £1,478.89 inc VAT
For those who want the ultimate gaming laptop then look no further than the OcUK Ultimate Gamer P370SM. If you need serious graphics gaming horsepower, this laptop features a pair of ATI Radeon HD 8970M 4GB cards configured in Crossfire. With the latest 4th generation (Haswell) Intel Core I7 Processor there is no shortage of power and for those who only demand the most powerful, we can construct the OcUK Ultimate Gamer P370SM with an Intel I7 Extreme processor too. Though our own in house testing shows the best bang for buck performance comes from the Intel Core I7 4800MQ & 4700MQ processors, so we highly recommend these when choosing a processor option.
This chassis uses the absolute very latest in technology such as SATA3, USB3.0, Bluetooth, WiFi but the most impressive of all is the fact this system features two ATI Radeon HD 8970M with 4GB of GDDR5 in Crossfire configuration. dedicated memory for absolutely blistering performance. With so much video memory and such horsepower you can even output to a 30" monitor and still have great gaming performance or run a multi-monitor setup.
With an LED backlit 17.3" screen with True HD (1920x1080) resolution games have never looked so good on the go or ran so smooth due to the power of the ATI Radeon HD 8970M onboard graphics cards in Crossfire. The OcUK Ultimate Gamer P370SM features high quality THX speakers with Sound Blaster cinema technology for the ultimate gaming experience.
For memory we only use the highest performance and most reliable for laptops, which is Corsair Vengeance which is set to run at 1600MHz with T1 memory timings resulting in absolute instant response. 8GB is the default choice which is more than adequate for all task and gaming, we only recommend 16GB kit if your also doing a lot of photography work or heavy multi-tasking. Corsair Vengeance 1600MHz will extract the very best performance from the OcUK Ultimate Gamer P370SM causing zero bottlenecks in the system.
Specification:-
- Display: 17.3" SuperBright LED True HD (1920x1080 Resolution)
- Graphics: 2x AMD / ATI Radeon HD 8970M 4GB GDDR5 Graphics Cards in Crossfire
- 1x HDMI Port
- 1x DisplayPort
- 3x USB3.0 Ports
- 1x USB2.0 Port
- 1x DC IN
- 1x RJ-45 Jack
- Dimensions: 419 (W)x293 (D)x 39.3.3~49.7 (H)mm
- 3.9Kg,including ODD and 76.96WH Battery
- 9in1 Card Reader
Service Package
Immense performance, powerful graphics and sleek hardware all combine to create the "OcUK Ultimate Gamer P370SM, perfect for the gaming enthusiast.
From £1,478.89 inc VAT.
ORDER NOW
OcUK Ultimate Gamer P370SM3 17.3" 120Hz 3D LED Full HD Intel Haswell Processor, 1600MHz DDR3, SSD + HDD, NVIDIA GeForce GTX 780M 4GB GDDR5 SLi Graphics Cards - Windows Laptop - Black @ £2,198.89 inc VAT
For those who want the ultimate gaming laptop then look no further than the OcUK Ultimate Gamer P370SM3. If you need serious graphics gaming horsepower, this laptop features a pair of NVIDIA GTX 780M 4GB cards configured in SLI. With the latest 4th generation (Haswell) Intel Core I7 Processor there is no shortage of power and for those who only demand the most powerful, we can construct the OcUK Ultimate Gamer P370SM3 with an Intel I7 Extreme processor too. Though our own in house testing shows the best bang for buck performance comes from the Intel Core I7 4800MQ & 4700MQ processors, so we highly recommend these when choosing a processor option.
This chassis uses the absolute very latest in technology such as SATA3, USB3.0, Bluetooth, WiFi but the most impressive of all is the fact this system features two NVIDIA GeForce GTX 780M with 4GB of GDDR5 in SLI configuration. dedicated memory for absolutely blistering performance. With so much video memory and such horsepower you can even output to a 30" monitor and still have great gaming performance or run a multi-monitor setup.
With an LED backlit 17.3" screen with True HD (1920x1080) resolution games have never looked so good on the go or ran so smooth due to the power of the NVIDIA GeForce GTX 780M onboard graphics cards in SLI. The OcUK Ultimate Gamer P370SM3 features high quality THX speakers with Sound Blaster cinema technology for the ultimate gaming experience.
For memory we only use the highest performance and most reliable for laptops, which is Corsair Vengeance which is set to run at 1600MHz with T1 memory timings resulting in absolute instant response. 8GB is the default choice which is more than adequate for all task and gaming, we only recommend 16GB kit if your also doing a lot of photography work or heavy multi-tasking. Corsair Vengeance 1600MHz will extract the very best performance from the OcUK Ultimate Gamer P370SM3 causing zero bottlenecks in the system.
Specification:-
- Display: 17.3" SuperBright LED True HD 120Hz 3D Display (1920x1080 Resolution)
- Graphics: 2x NVIDIA GeForce GTX 780M 4096MB GDDR5 in SLI
- Built in 3D IR emitter plus one NV 3D Vision 2 shutter glasses
- 1x HDMI Port
- 1x DisplayPort
- 3x USB3.0 Ports
- 1x USB2.0 Port
- 1x DC IN
- 1x RJ-45 Jack
- 9in1 Card Reader
Service Package
Immense performance, powerful graphics and sleek hardware all combine to create the "OcUK Ultimate Gamer P370SM3, perfect for the gaming enthusiast.
Only £2,198.89 inc VAT.
ORDER NOW
  • FAST TRACK SERVICE - You can pay a small fee to have your laptop with you within 24hrs
  • No Clutter, freeware, our laptops don't come with anything pre-loaded except the O.S. as such maximum performance.
  • Latest Drivers pre-installed to ensure latest compatibility and maximum performance
  • 2yr Warranty (2yr labour, 1yr parts)
  • Excellent price for the performance on offer compared to big brands
Hi there
Also depending on which GPU is present they come with either Batman PC Game or AMD Golden ticket entitling you to three free games. :)
The "price" might have dropped, but so has the default CPU...dropping from the i7-4700MQ down to a i5-4200M. Changing the CPU back to i7-4700MQ...the pricings are still more or less the same as before...? :confused:
So rather than "price drop", wouldn't be "new cheaper i5 CPU option for laptops now available" be more appropriate?
No.
All the prices have being reduced anywhere between £20-£50 along with a cheaper CPU option too which further reduces prices. But a price drop has indeed happened! :)
No.
Nevermind...it could be that I was remembering the deal prices, and your price drops was referring to the normal pricings.
The price on the 13" is even cheaper?! :eek::eek: that's a nice price! Considering the extras thrown in other places charge for... can't fault, can't fault.
Don't forget Batman game too as its got a NVIDIA GPU in it.
We throw the extras in free of charge simply as we'd not let the laptops leave our premises without the uprated thermal compound, as they simply over-heat and crash, so its a must to be honest.
