***The Vapers Lounge***
Status
Not open for further replies.
I have another set of juices from Scope today, woop woop.
If you guys saw how much e liquid I have you'd swear considering I only started just over a month ago xD
I'm getting a bit bored of my SVD now though and want a much smaller mech mod, preferably telescopic that will fit my 350's and 650's in. Then I have something small and fancy to go with my Kayfun/G Bell :)
Well isnt that just ****ing great, somehow i had a brain fart moment and decided what an awesome idea to put an open bottle of juice on my bed..cue it leaking all over my duvet cover:eek:, leaked through to the actual duvet itself. Managed to whip it off and sprayed plenty of febreeze onto my duvet, dont know if that will help the smell of it.
Damn my missus is absolutely going to kill me lol
I'll be buying the JB Steamworks RSST Reducer when it drops next week from smokecloud...watched 3 reviews now, all say it's a far far better vape with it installed...
Lol lets hope she doesn't notice. :p
My bedroom smells like a sweet shop most times, as i leave my DIY juices steeping on top of my wardrobe and custard can be a very strong smell.
Just say you took the lid off a juice to let it steep better?
Thats very kind of you and hope they go to a good home.
I got about a litre of custard steeping right now so shouldn't need to buy anymore juices this year.
:D ;)
What recipe did you use if you dont mind me asking?
I done 5 different batches of VC to see what the difference the main flavours do.
i mixed
1.
VC 17%
FVD 5%
EM 2%
2.
VC 17%
FVD 5%
Em 2%
DDL 2%
3.
VC 17%
FVD 10%
Em 2%
DDL 2%
4.
VC 17%
FVD 5%
EM 2%
DDL 5%
5.
VC 25%
FVD 6%
EM 2%
My usual mix had DDL in it, but just tried mix 1 tonight and its lovely but has no DDL in it lol :confused:
My neighbour is also a Vaper, so might give him a sample of each one to see what he prefers as well.
Might ask for marks out of ten for flavour, creaminess and sweetness.
Sadly my missus isnt stupid lol, curse my luck for marrying a smart lady but i do the same with my juices, i leave the caps off them and let them steep for a week or so.
At the moment, my room smells of scopes raspberry lol.
2.
VC 17%
FVD 5%
Em 2%
DDL 2%
No.2 is the closet to my mix. I don't like adding too much FVD, makes it taste a bit chemically. I have the the custard steeping and after I few day I add other favours to see what works. I added some popcorn to one mix and gives a nice sweet buttery nut after taste.
Do you have a budget in mind?
£20 Sentinel Clone in all Brass or Brass & Aluminium (hits just as hard as the $200 original)
http://greyhaze.co.uk/collections/mechanical-mods/products/sentry-telescoping-mechanical-mod
£30 Sigelei 19B SS Telescoping Mod (I have one of these, truly excellent entry level mod):
http://www.kernowvapes.co.uk/Sigelei_19b_telescope/p2086842_9814505.aspx
Also available in Brass at GreyHaze.co.uk:
http://greyhaze.co.uk/collections/m...s/sigelei-19e-telescoping-mechanical-mod-ecig
but definitely upgrade the top cap as SS attys wear out the softer brass 510 connection:
http://www.kernowvapes.co.uk/Sigelei_19b_head/p2086842_9867886.aspx
Spend a little more on an NZonic clone, which suits the Aga T2 Genesis very well for under £50:
http://www.kernowvapes.co.uk/DHX_-_028_telescope/p2086842_10433389.aspx
Or if you only want to buy the one telescopic, spend more on something Greek:
GP Paps 2.5 is superb for around £85:
http://www.vapist.net/Gp_Series_by_Vapourart/cat2068658_1898061.aspx
The Polish made Unser (by Witcher Mods) is great value at £80:
http://www.vapist.net/The_Unser_by_Witcher/p2068657_10408213.aspx
The Roller is fantastic for £90ish and pretty customisable:
http://www.atmizoo.com/shop/roller-ss-m/?lang=en
The Poldiac is very special but obviously you pay for it (approx £120-£130):
http://mmvapors.com/page/default.asp?id=63&la=1&ctID=26
Or go all out and get yourself a Hybrid:
http://www.vapist.net/Ikarus_V21_Hybrid_by_Dropmods/p2068657_10541924.aspx
Happy Spending! :p
Happy Spending! :p
Curse you Redmogg, pretty shinies must be mine!
The sigelei, GP Paps, and roller are the ones that appeal, I can probably pick them up on UKV too.
I've also been debating the chi you clone and the ithaka clone from fasttech but having problems deciding which. I already have my g bell and Kayfun lite which I use both of all the time so the ithaka would probably hardly get used. All my iclear 30's, protank etc rarely get used as they're rubbish in comparison now. Might grab myself an igo W though as a third tank.
@Scorch is that a nemesis clone from Fasttech?
I've been struggling to decide between that one and the chi you from fasttech until Redmogg threw all the other mods into the mix I was debating which are all a bit ouchy in terms of price until I know whether or not I like the mech mods.
I believe that's also the dingo, bagua and poldiac?
If I'm right on all the above can you tell me whether or not they are clones and your opinions on them over the SVD please? :)
One for every day scorchisio? :) nice collection mate
Might be too early but what is the nemisis clone like?
I have had my eye on one, but have a bog standard sigelei mech mod here but like the look of the nemesis clone better
And thx smokedog, no 2 is my normal recipe, but wanted to add extra of the other flavours to just and try to understand what they bring to the mix.
Status
