51-55" television
Don
18 Oct 2002
Cornwall
hi guys,
I know there are plenty of threads here covering recommendations for this sized telly, however all the models favoured (e8000, gt50 etc..) now all seem to be unavailable, so I'm wondering what the best model of the moment is?
I have around a grand (£1300 max ideally but in no hurry to spend that if I can get a decent set for £800 or whatever) to spare, room is light controllable so please let me know your opinions.
thanks in advance for your help :)
Im in the same situation.
Been looking at a number of sets but keep coming back to the SE55f6670 / SE55f6740
http://www.johnlewis.com/samsung-ue...-and-voice-control-with-2x-3d-glasses/p437706
As soon as payday comes around Ill be looking to pricematch this with crampton and moore for £1250 to get the warranty.
Lots of people seem to be reccomending the panny gt60 if you want a plasma set.
Samsung seems to have the best smart services which keeps bringing me back to them despite the fact it'l be hooked up to a pc at all times anyway and will probably never get used.
If LED is the way you want to go then I would also suggest the Samsung 6670 / 6740. The only difference between them is the stand colour.
The image quality is up there, it looks amazing, has all the catch up apps, active 3D, built in wireless and comes with the touch pad remote.
anyone else with a 55ST60b, I use these settings but alternate the ambient sensor on and off during the day :)
Viewing Mode: True Cinema
Contrast: 57
Brightness: 0
Colour: 50
Tint: 0
Sharpness: 0
Colour Temperature: Warm
Vivid Colour: Off
Colour Remaster: Off
Ambient Sensor: Off
Noise Reduction: Off
Page 2
MPEG Remaster: Off
Intelligent Frame Creation/24p Smooth Film: Off
Advanced Settings
Panel Luminance Setting: Mid
Adaptive Gamma Control: 0
Black Expander: 0
Colour Gamut: Normal
White Balance 2-Point:
White Balance
R-Gain: -3
G-Gain: -6
B-Gain: 0
R-Cutoff: 0
G-Cutoff: -2
B-Cutoff: 0
White Balance 10-Point: 10 R 1/G5/B-5, 20 R-6/G13/B-4, 30 R0/G-8/B-6, 40 R-2/G1/B0, 50 R2/G6/B-2, 60 R0/G4/B1, 70 R-6/G0/B-4, 80 R-3/G2/B-3, 90 R-7/G1/B0, 100 R-3/G3/B17
Colour Management: Red Hue -17, Saturation 19, Luminance 2, Green Hue -12, Saturation -43, Luminance 1, Blue Hue 0, Saturation 0, Luminance 1,
Gamma: 2.4
Gamma Detailed: 10 0, 20 14, 30 4, 40 1, 50 1, 60 0, 70 0, 80 -4, 90 -4, 100 0
Option Settings
Game Mode: Off (unless gaming)
Film Cadence Mode: On
1080p Pixel Direct: Needs to be tested with source
Screen Settings
16/9 Overscan: Off
Side Panel: High
Pixel Orbiter: Auto/On - personal choice
Don't use settings from other calibrated tvs it doesn't work that way.
Keep them stock or self calibrate or get a professional calibration.
Using someone else's settings is like using someone else's lottery numbers.
