- 21 Jul 2005
- Officially least sunny location -Ronskistats
The FX83 doesn't have consistent performance, it needs to be fully utilised to realise its full performance.
So it can go from scoring under a 4670K, to being neck and neck with a 4770K.
For gaming though, like I say, in 99/100 cases, it's no better than what you have.
In encoding etc, the FX83 will be a fair amount higher than your i5 750, as it has a much higher potential performance at 100%.
But, you're far better to stick with what you have, and then get the newer AMD stuff when AMD reveals their hand, as that could be quite good (And definitely worth the upgrade to)
AM3+ is all but dead, it may not get an update to it for new CPU's.
Do bear in mind, in reviews, your CPU's clocked 1.4GHZ lower, which is massive.
The FX8320 offers tremendous price/performance, but you're coming from something which is already a very good performer for gaming.
The FX83 is the better CPU, and you'll notice gains in situations that are heavily threaded, but gaming, you're literally going to be wasting your money, except for that 1/100, but then again, you'll definitely benefit in the long run to see what AMD do, as we should find out very soon, the FX83 is coming up a year old and Kaveri (Steamroller) is well on its way to launching and that'll give us an inkling to AMD's future 8 cores.
Cant argue with this its a well constructed post. +1
