OK I might try overclocking it more, I just used the Ai tweaker in the BIOS which automatically overclocked to 3.7Ghz.
Just thought what if I got a second hand i7 860?
+1. The 8320 will save you £30 to put toward a cooler but as los says check out the game on release before judging.
The 4770k is £240 alone and should not be directly compared to a £100-150 CPU.
Well, anything more than that is pointless as the game becomes totally fluid around 45-50fps. Maybe I'm missing something but I don't see a point spending 250quid to move from 100% smoooth gameplay to 105% smooth gameplay : ). You'll maybe get jump to 75-80fps at best but it won't be noticeable in the game or to the eye unless you look at the fps counter instead of playing.
Just my 2p
and get 3fps extra which you could get by OCing the cpu by 300mhz more, totally worth it right ? ; )
Try overclocking the i5 further, and overclocking the 680.
Simple answer is if you are going to be playing BF4 a lot, then... why not? Go for it.
For an FX83XX to get the same core for core performance as your 3.7GHZ, you're looking at like 4.5GHZ.
my RAM is running at 1600Mhz with 9-9-9-24 cycle is that good?
LOL sorry dude but you're seriously having a laugh with that.
http://www.3dmark.com/3dm/1333256
There's an I5 750 running 3.8ghz and look at the Firestrike Physics score ! It sucks monkey balls
The 8350 IMO will offer up double the performance of the 750. It wouldn't surprise me at all if the 8350 had the same or a higher IPC only with double the cores.
/Facepalm.
Core for core.
Core for core.
Keep reading until you understand what it means.
So, the OP should sidegrade for 99/100 games, when he's got a CPU that's perfectly capable.
That's cracking advice that is.
