- 1 Aug 2012
- Stoke-On-Trent
Same as title,Thinking of Xmas present for my brother.
Many thanks
Many thanks
Cheers![]()
The specs are similar because that combination makes the most sense for $199 on the GCN architecture.Treat him to one of these, its what, £10 more...
http://www.overclockers.co.uk/showproduct.php?prodid=GX-049-HS
From the reviews I've read, the 270 looks to be slightly quicker than a 7870.
Though the specs are similar to a 7870, the 270X is most certainly not a 7870.The specs are similar because that combination makes the most sense for $199 on the GCN architecture.
That said, the 270X is not compatible with the 7870. It *might* work with the 280X, but I make no promises.
Clocks and drivers.
You also don't know what results they're using for the 7870, it could be launch day ones.
Time will tell I guess, though personally I can't see it being all that much faster. If it is, I might pick up one.![]()
Get a 7950 yellow sig man, while you still can.![]()
Yeah, you're probably right, Matt.
Btw, those sapphire toxic cards look nice. I'm not a lover of that brand, but maybe I could be swayed on this occasion.
I think you should add a pipe and brightly coloured wig to your sig.![]()
Though the specs are similar to a 7870, the 270X is most certainly not a 7870.![]()
Erm, yes it is.
I think you have the side of the 290X wrong Humbug, I thought it was 530mm^2 or something?
'About' 17.5% larger than Tahiti XT, 428mm^2, there is an article some where with the diagrams stating its 437mm^2. those spesifications are apparently confirmed, i will try to find them.
Its about 25 to 30% smaller than GK110.
