Asus HD 7970 DirectCU II TOP today only price
14 Jan 2011
Hi guys.
On the front page the description says
You'll never see an offer like this again, an Asus HD 7970 TOP for under £200 - BUY NOW!!!
But as far as I can see the price is 209.99.
Does anyone know whats up?
I bought the Platinum version a couple of hours ago at £235.99 & its now £229, im guessing the price is going to drop some more :(
Edit: over it now, im getting one hell of a card for cheap so turning that frown upside down
Hi there
A bit of an error by me on the prices, TOP was too low on stock in the end to offer a sub £200 price.
However tweaked the Matrix Platinum price down, it is now £221.99 which is the cheapest its ever being anywhere. :)
P.S. Drop a post in CS forum and they will refund the difference as your order would not have shipped yet. :)
Oh my, I just bought one, talk about a reflex purchase. Don't know if it fits, have enough power adapters, who cares. Happy days!!!!!!
I want to buy a Matrix now, can someone tell me if I can hook this up fine without any extra connectors?
I currently have a 6950 and this is connected using an Antec TruePower 650? Do I have the correct power cables on this or not?
cheers
yes, just looked, I have two 6 pin being used and a 2 pin free dangling on the PCIE cable. Are there 6 pin to 8 pin adaptors or something?
There are converters yes but I am not 100% sure if it will work, it will depend on the card/PSU in use I guess.
AFAIK 8 pin connectors are rated at 150W, whereas 6 pin only 75W, so even with an adapter there might not be enough power going to the card?
Perhaps someone on the forum has first hand experience?
