- 12 Jun 2006
Got my new parts 2 days ago and I started OCing today. So far I was able to achieve 4.6Ghz with 1.26v Vcore. Here are the settings I used on my Gigabyte UD4H:
multi 46
Vcore 1.26
Uncore multi 46
Uncore Voltage Auto
CPU VRIN override Extreme
BLCK Auto
Turbo Auto
C1E, C3, C6/C7 EIST all Auto
For stability I used AIDA64, run it for an hour, average temps were 64-70 across all cores and highest temps were 81-85.
A few questions:
1)Are these results any good?
2)Based on these results, would you say that my chip is above average?
3)Can we say that after 1 hour of AIDA64 the OC is stable?
4)Uncore to multi ratio is 1:1, is this ok? If not, what should I do?
5)Is there an option I can enable to have the CPU use less voltage and drop multi when it doesn't need the extra power? I beleive it's called Adaptive?
6)Any advice/opinions/extra tips are welcome
. I don't want to push the chip to it's limits, but I feel like I have some room for improvements
multi 46
Vcore 1.26
Uncore multi 46
Uncore Voltage Auto
BLCK Auto
Turbo Auto
A few questions:
