We should really create a subforum for PC code giveaways
it's up to the OP also don't forget that the giveaways forum has the same restrictions as MM so if OP decides they want less strict rules then there's no point posting it in thereHow many times does it need to be said, it is not required that giveways be posted in the giveawys forumit's up to the OP also don't forget that the giveaways forum has the same restrictions as MM so if OP decides they want less strict rules then there's no point posting it in there
Also not sure if OP has access himself
Yes! It is clearly stupid for giveaway threads to go in giveaway forum. Sorry for suggesting it.
I notice most food related threads posted in GD get moved to Cuisine forum even if the OP probably intended it to go to a larger audience etc.
