Man of Honour
- 12 Jul 2005
- Aberlour, NE Scotland
So did i but they are still at it. It's always the same people too.
To be fair the O/P asked if upgrading from an i5 750 to AMD 8350 would be worthwhile.
The Core i5 4670K is slower than an FX8350 in the most CPU intensive part of Crysis3 though:
http://www.pcgameshardware.de/scree...Test-Haswell-4770K-4670K-4570-Crysis-3-v2.png
The Core i5 760 is around Phenom II X4 level in the game.
And it won't be, not for gaming in the current climate.
I always use my own findings based on having the hardware to make my decisions. Synthetic benchamarks from the net can show whatever the reviewer feels like tbh.
Upgrading now is a bad idea, We have no real idea how things will pan out over the next few months. Best to hang on for now and re-assess in a couple of months.
For crying out loud stop bitching, it's pathetic. You lot are ruining this place. It used to be just the graphics card section but now this one is going downhill too. Op asks a simple question and we end up with 116 post's of bitching. How about somebody actually helps someone for a change instead of destroying peoples threads?
The 8350/20 are great value CPU's but they really cannot compete with the Intel's at the moment.
Just my 2p's worth.
Its a discussion, even if some get a bit protective about their choices. I think the thread has offered a good insight into the current state of cpu performance directly relevant to the OP's needs.
That's one reason I'm pro i5,
You can only have a valid opinion if you own both?
Talk about a contradiction.
OTOH Martini you do a fair bit of underlining how impeded the FX range is ('clocks and cycles'), and in other threads actually recommend it (when it suits).
That is talking about contradiction.
It's not a contradiction, its a different context, if a person has a Core2 system or no computer and is looking to buy/build a cheap system then the FX are a great option for the money. If however like in this case the person already has a 1st gen i5 setup or newer then moving to an FX setup isn't really worth it.
Not directed at anyone, dunno what your implying...
It's basically saying if anyone has a balanced measure it's this lad.
Pcgameshardware does far more intensive tests than most websites. If they get weird results,they tend to do more testing than other websites.
So I give advice based on the situation as opposed having a slanted bias towards a vendor?
I wouldn't call that contradictory.
!I'm Oot
