Looks good Chris, blue is not a colour I would normally pick but that looks great hmmmm ideas inbound
It is available separately. Corsair 350D Solid side panel
Right hand side only.Thanks man! It might sound weird but I don't really like the plastic windows so much. They scratch so easily and act like a magnet for dust. And I hate seeing the dust![]()
How is the window fixed to the case?
yep! im wondering if i can get a sheet of glass cut for mine instead.. think its doable?
yea should be. Might be difficult to get it to sit flush like the current plastic window. You would have to send the side panel off to a pro
I was wondering if you could take the side panel to a local glass shop, somewhere that does photo frames or mirrors perhaps.
i've found a special glass manufacturer gonna talk to them tomorrow, see if i can also have some tiny holes drilled into the glass about 3 or four lines of tiny holes, all the way across the bottom for aesthetics
