- 30 Jul 2012
Have i got a poo overclocker? My FX 6350 can only manage 4.6 @ 1.51v
You'll definitely need a mixture of FSB and multi. There's no way of going higher without both.
Calm down on the volts and get to making sure you have been using both.
Ed. What CPU cooler are you using?
Swiftech polaris 120, i will try a mixture.
When would i need NB voltage?
I have always achieved my best overclocks on both FSB and multiplier.
You must use both on AMD IMO.
I have a second set (board and CPU) and it's a 4+1 crapola 990FX Extreme 3. I got it to 4.2ghz (8320) but with that board I could not touch the multi AT ALL. I had to just use the FSB. One notch up the multi, even with stock everything and it refused to post.
Will be setting them up again over the coming weeks, but even with my CHVFZ I need to use both multi and FSB in order to hit 5.2ghz.
I am surprised you could even run it on the extreme 3 at stock without throttling.
Currently sporting two Formula-Zs and a Sabertooth. The formula-zs have the VRM/nb and the CPU under water. On multiplier alone, i can get no more than 4.6GHz but on both, hitting 5GHz isn't that difficult or time consuming.
Spent more than 24 hours trying mixtures, always requires 1.51v at 4.6GHz. Will not go further unless i seriously want more voltage which i do not.
