- 22 Dec 2011
So I've just done a complete tear down and rebuild of my pc in order to clean and install a H100 cooler. Booted fine but I was getting no signal from the gpu, switched to the output from the motherboard and went to device manager, only display adapter is a "Standard VGA Graphics Adapter"?
I've done the following:
Both GPU's have power, fans spin but no video output or system recognition. Please tell me I've missed something simple? As both cards work in another system I can only think I've somehow damaged the motherboard or PCI slots?
- Stripped out all non-essential parts
- Re-installed the gpu (several times, checking properly seated and powered)
- Uninstalled drivers and GPU, ccleaned, rebooted, reinstall drivers (tried both current and beta) then GPU
- Couple of different cables to monitor
- Using the other PCI slot
- Using an old gpu in both PCI slots
- Confirmed BIOS is set to use PCI
- Tested both old and current GPUs on another mobo with same psu (both recognised first time, good video output)
- Cleared Cmos (via jumper and battery removal)
