Asus HD 7970 Matrix Platinum 3072MB
30 Aug 2011
Hi , Just wondering if someone can confirm if these cards work with HDMI. If so does it include a dvi-hdmi adaptor and does the audio work via the dvi?
Also, would a 700watt psu be ok for this card.
Thanks
I'm sure there's 1 HDMI slot at the back of the card already, so an adapter isn't required. and 700w is plenty.
ok specs say
- Display Outputs: 2x DVI + 4x DP-
I am assuming there has to be an adapter for dvi/hdmi.
someone else whom have purchased one can confirm this?
I got the TOP the other week and this come with a DVI-HDMI adapter, hopefully the Matrix does.
That's good to know, thanks for your help.
Finally, before taking the plunge. I'm not sure my old gigabyte z68 board will allow for the cooler on these cards. Could someone spec me a m/board, Z77-1155, around £100 (hopefully) that can fit the Matrix, cooler and all.
Cheers
