Permabanned
- 4 Sep 2011
- Durham
Hey,
So I built a new PC about 6 month ago and have not had a single problem with it. Howevert I turned it on this morning and the corsair 120 performance 4 pin fan at the rear of the case which is plugged into the motherboard direct seems to lose power every 2 seconds then spin for 2 seconds then lose power. All parts were bought new when I built it so any ideas? The PSU is a corsair ax1200i and the rest of the fans on the case are ok and the cpu fans for the h100i are ok also. Only the single rear fan has this problem and its plugged into the mobo directly. I powered down and unplugged the fan then plugged back in and it seems ok but I cant help but worry its an underlying fault
