New car battery
21 Oct 2002
Wellington, NZ
Bit confused. I need a new battery.
Looking at the Bosch S4 for 50 quid from ECP and there's two types. There's the S4 155 and the S4 159. Identical price.
The only difference I can see is the terminal type. One is EN and one is 3 JIS. Which do I need?:confused:
Duracell AA should do it.............
Seriously a little help such as what car its for may help! Have you put your reg into the ecp checker?
Think it's JIS for Jap crap, narrower connectors but don't hold me to that.
Is it the same size as the EK9 i.e. small? If so I think it's the same as the first Honda Jizz if they don't list CRX on shop systems
In sig and yes. Brings up both.
Muffin no it's standard size. The 159 appears to have three terminals :confused:
Bosch website says;
Civic CRX Eng- 1.3/1.4/1.5/1.6 , i, i 16V Yrs- 10.83-02.92 45a/330a S4 023
So you should be after the S4 159
Dont know what the difference is
