** Corsair Graphite 230T Available to Pre Order Now **
rjk
rjk
OcUK Staff
8 Aug 2007
Hi Guys
Due very soon we have the new 230T available from Corsair.
This mid range chassis is ideal for gaming systems and offers a nice feature set for the price.
It also comes in a mental orange colour for people wanting their systems to really stand out!
Stock due soon.
Corsair Graphite Series 230T Compact Mid Tower Case @ £57.95 inc VAT
The Graphite Series 230T mid-tower PC case has a striking, leading-edge look for building fast systems that look just as fast as they run. The sculpted exterior features dual intake fans bathed in soft, color coordinated LED lighting. Inside, it has the system builder-friendly ergonomics and cooling and expansion flexibility that Corsair is known for. With smart features like dedicated SSD bays and our innovative cable management system, builds, maintenance and upgrades are fast and easy.
Graphite Series 230T is a great choice for gaming PCs, graphics design workstations, or any application where high performance and high style both matter.
Features:-
- Dual 120mm front LED fans and rear 120mm exhaust fan.
- USB 3.0 front panel
- Tool-free SSD, HDD, and ODD installation
- Cable routing and CPU cooler backplate motherboard cutouts
- Seven PCIe slots with thumbscrews and room for GPUs 320mm long
- Install up to four 3.5¡¨ and four 2.5¡¨ drives simultaneously ¡V tool free.
- Up to six fan mounts for optimal cooling potential
- Dust filters for front and PSU intake.
- Room for up to 200mm ATX PSU (not included)
Box Contents
- Graphite Series 230T case
- Quick Start Guide
- Accessories box with screws, zip ties, and other mounting hardware.
Only £57.95 inc VAT.
ORDER NOW
Corsair Graphite Series 230T Compact Mid Tower Case Windowed - Black @ £66.95 inc VAT
The Graphite Series 230T mid-tower PC case has a striking, leading-edge look for building fast systems that look just as fast as they run. The sculpted exterior features dual intake fans bathed in soft, color coordinated LED lighting and a tinted side panel window. Inside, it has the system builder-friendly ergonomics and cooling and expansion flexibility that Corsair is known for. With smart features like dedicated SSD bays and our innovative cable management system, builds, maintenance and upgrades are fast and easy.
Features:
- Tinted, flush-mount side panel window.
Box Contents
- Quick Start Guide
Only £66.95 inc VAT.
ORDER NOW
Corsair Graphite Series 230T Compact Mid Tower Case Windowed - Orange @ £66.95 inc VAT
Features:
Box Contents
- Quick Start Guide
ORDER NOW
Corsair Graphite Series 230T Compact Mid Tower Case Windowed - Grey @ £66.95 inc VAT
Features:
Box Contents
- Quick Start Guide
ORDER NOW
Does that orange case burn you if you touch it?
On another note, is there more pictures for these cases.
Looking great value.
Thanks, quick question. Does this support tri-sli on an ATX mobo? Or is it another midi case where the PSU will be in the way?
because you need the room and associated features to support the cooling required for such a set up.
this is a mid tower case. around the same size as an antec 300 or bitfenix shinobi.
not the best condition to be running a high heat output graphics configuration.i would personally be looking at spending a little more to grab a 540 air.
that way there is no psu impeding airflow into the case and there is plenty of fan space in the case
Pretty basic case to be honest and don't really see the point of it when the 300R can be had for the same price. Very much reminds me of the Antec 300.
if you're looking at running Tri SLI
you shouldn't really be looking at £70 cases.
Yeah i know, but i just wanted to know if this mid tower will fit a gpu in the bottom sli/xfire slot, or will psu block it.
The amount of midtower cases that do allow this is very limited.
I ran crossfire in my mid case with a non modular PSU stacked to the gills with 200 and 140mm fans and all the rear slots used up. Machine didn't break a sweat.
