Why are people not having a car from each category for the races stored in their garage? Custom cars blitz others using normal cars.
RIght so...get his Play disc CopyInstalling on a USB memory stick helps remove the texture poppipng that you get if you install both disc's to the hdd. As said though, the disc is not tied to your console so if you have a memory stick around, install your mates play disc to the memory stick (will have to format it first on the xbox) and then try to play from your scratched disc. As I said on the last page, as long as the xbox can read enough on your disc to verify that it is a genuine disc it will then read everything else from the memory stick and you shouldn't have any problems them![]()
This is my 10 car shopping list (some I already have)
Vacca
Sandking XL 4 seater
BF Injection
801RR Bike
Dominator
RH8
Entity XF
Rapid GT
Karin Sultan RS
Rat Loader
Copy to my formatted USB stick.
Keep MY original disc, scratch and all, in the hope is just gets enough to verify its mine then it will hopefully read the rest off the USB stick?
Karin Sultan RS
rat loader? wtf? why?
Sultan only becomes an RS when you add the roll cage.
Just look funny when modded with engine through the bonnet and big truck exasust going down the side.
Ah ok, didn't know that.
Yes. If it doesn't work then I would consider going to one of the retailers that offers to remove the scratches, though IMO this should always be the last thing you try.
Want one! Where would i find one of them?
Thanks for your help, but just thinking I don't think it will work, as even the dashboard it straight up says in the tile the disc is not readable, so it may not even try and load. Will give it a go any ways.
As far as Im aware none of the shops in Belfast have the service to skim the discs, wonder if I have to send it off.
