It has been a long time since I have been on here, so please bear with me. I am a little behind the drag curve with the very latest/cheapest technology.
Quite a few years ago I rebuilt a nice PC for my daughter for general surfing/emailing and carrying out her internet banking from her own place.
The PC has suddenly failed with continuous beeps and a code of CC from the Abit motherboard readout display. This happens when the power supply cord is put into the back of it and the supply switched on. Nothing else happens. I was advised by a local guy that the motherboard has failed.
The case and all its peripherals are good quality and rather than throw it away, I would like to rebuild.
Could some kind gentleman please suggest the way forward, so that we have a fully working PC at minimum cost.
1. It is an ATX aluminium Lian-Li Midi Tower case with 4 large and 3 small bays in the front. The panels are all removable and it is easy to work on with knurled screws used for assembly for the majority of the peripherals except for the mounting of the motherboard.
2. The failed motherboard is an Abit IP 35 Pro XE.
3. It has 2 x 1GB Geil DDR2 800 RAM (PC2 6400). (presumably not used on later boards). Anyway, 4gb in my view should be the minimum)
4. Intel E5300 Pentium Dual Core CPU. (presumably not worth using again?)
5. Palit 7800 GT 512 PCI-E graphics card.
6. Power supply.
7. LG DVD re-writer.
8. A 3.5" floppy.
9. Two 500GB Hard drives.
10. Windows XP installed.
11. Quality keyboard.
12 Microsoft wired mouse.
All suggestions gratefully received.
Many thanks
6. Power supply.
8. A 3.5" floppy.
Many thanks
