Hi,
Edit: TLDR: Tank of water is nice and hot and as such the heating sources are not firing much, but the water out of the taps is luke warm (but pressure is fine).
I appreciate these pictures look a mess, the pipework doesnt mean a lot to me, but i am hoping that it may look simple to someone on these fine forums who actually has a clue about hot water systems!
I am not actually sure what type of system this house has, is it unvented? When turning off the cold mains supply all water trickles to a halt including the hot taps, after a little initial surge?
The issue we currently seem to have is that water is only coming out luke warm, almost too cold to shower, this happened suddenly one day, and i have no idea why. The immersion heater works fine, has a new stat, and upon pulling the stat out it is boiling hot and therefore not firing much. The whole tank feels very nice and warm so i know this is heating. The immersion isnt kicking in much (it fizzes when it does - always has) compared with before this happened, its almost like hot water isnt being drawn off the tank and is somehow being diluted with cold. As i say the immersion has a new stat, and the tank feels just as warm as ever, but it is firing noticably less which my layman diagnosis has put down to hot water not exiting the tank?
So i know the top tank with internal float does the central (radiator) heating header, i know this as caused a leak before in our heating circuit and this emptied out
So this is where i dont know what the heck is going on. I figure that the electrical white & grey item above the immersion is the boilers temp sensor to call for heat (this isnt firing much since the issue, as the tank is already hot). The red pump i think is the boiler heating loop pump? (the boiler is downstairs - kerosene fired). The rest of it i have no clue about, the silver thing, the other silver thing, and what seem like piped with a million junctions.
I basically dont know how to even start resolving this luke warm water issue. If i leave the boiler switched off and use the immersion only (what we usually do, kerosene is a pain) its hardly firing, the tank feels really warm, but we run a hot tap receiving luke warm water for over 10mins solid, and the immersion barely kicks in and its stat still feels boiling hot as it should if removed from the slot in the heater.
