Best GPU for £300 or Under?
What you have is probably the best single GPU solution.
If you are prepared to use CF then a couple of HD 7950s will give you very good bang for buck but it will cost a bit more than £300.
Yeah, I would prefer to keep to just a single card so I think I'll stick with the asus, thanks for the help.
If that is the spec you want then do the chip+board a favour and give it some kick-ass RAM,
YOUR BASKET
2 x TeamGroup Xtreem LV 8GB (2x4GB) DDR3 PC3-19200C10 2400MHz Dual Channel Memory Kit (TXD38G2400HC10QDC01) £59.99 (£119.98)
Total : £128.68 (includes shipping : £7.25).
How much of a improvement is that over what I currently have?
I'd hold out for a very short time and buy the Sapphire r280x Toxic instead, fraction cheaper and better cooler.
