Only if its locked to three though?
True. What SIM did you put in first then?
not knowing it would lock, silly really.http://help.ee.co.uk/system/selfser...ment=consumer&isSecure=false&CMD=VIEW_ARTICLE
If you explain the situation perhaps they will unlock it now for you?
Don't know why they're making you wait. You didn't buy the phone from them so they won't lose any money via subsidies. You should complain and make as much noise about it as possible
What a fantastic case this is - randal you're a star. People are nothing but wowed by the case. Very happy chappy!
Just been on the phone to apple, they tell me that the iphone 5s, even though it states its unlocked, will lock to the first network you use. :/
It’s possible that your case is interfering with the noise cancelation feature. Try using the iPhone 5S with the case off, or head into Settings > General > Accessibility and turn Phone Noise Cancelation off to see if it makes a difference.
She said that because the phone was purchased sim free, that i need to have a payg sim in the phone for 6 months, minimum of 3 and they might try again.
They'll express replace your phone without AppleCare. Not sure how old they limit it too though.
If the phone is still within the 14 day return period they will send you a "retail" boxed device (cellophaned etc) rather than a white box replacement. At this point there will be very little difference between the two, considering they're all new - the only difference will be any changes that they've made in manufacturing (which I doubt will be any at this point, even with the gryoscope issues).
Otherwise, you have the option for an express replacement, where you swap at the door with UPS (IIRC) and they put a hold on your card for the cost of the device.
Worth noting that all I've heard are positive responses about call quality. People on the other end can hear me more clearly than on my Nexus 4, particularly in noisy areas (busy roads etc), and I must say that audio output during calls is much better too. Noise cancellation works well here. So what you're experiencing certainly isn't normal, though what the cause is can vary. Must say that signal is pretty poor on my 5S compared to the N4, however.
