Hi Everyone,
I'm in the market for a new PC. I would like to build it myself but I have a disability that unfortunately means I do not have the manual skills needed to put together a computer.
I was ready to order from another website when I stumbled across OverClockerUK's "Ultima 460i Scimitar".
The only thing is the customization is not as good with the OCUK machine but I don't know if having a water cooled system makes up for that.
Could you please give me your opinion on both specs?
Computer I
Case - Cooler Master: Cosmos II
Motherboard - Asus Rampage IV Extreme: Intel X79 Socket 2011 R.O.G.
CPU - Overclocked Intel® Six Core i7-4930K (3.4GHz @ max 4.4GHz)
RAM - 32GB Kingston Hyperx Beast Quad-DDR3 2400MHz X.M.P.
Graphics Card - 6GB Nvidia GeForce GTX Titan x 3
SSDs - 240GB Kingston Hyperx 3K SSD x 2 (Raid 0)
PSU - Corsair 1200W Pro Series Platinum AX1200i
PSU Cooler - Corsair H100i Hydro Series
Sound Card - Creative Sound Blaster ZxR 5.1 PCI-E
Optical Drive - 15x BLU-RAY WRITER DRIVE, 16x DVD ±R/±RW x 2
OS - None
Warranty - 3 Year Collect & Return, 3 Year Parts, 3 Year labour
Cost = £4,838.00
Computer II (Ultima 460i Scimitar)
CPU - Intel Core i7 4770K 3.50GHz @ 4.50GHz Quad Core Haswell
Motherboard - Gigabyte Z87X-OC (Socket 1150) ATX
RAM - 16GB Team Group Vulcan Orange 2133MHz Dual Channel Kit
Hard Drive - Seagate Barracuda 2TB
SSD - Samsung 840 Series 120GB
Graphics Card - Watercooled Radeon HD 7990 6GB GDDR5
Sound Card - Realtek 7.1 Channel Sound (On-Board)
Optical Drive - OcUK 24x DVD+/-RW SATA Drive
OS - None
Warranty - Full 24 Month collect and return
Watercooling Specification:
- Radiators: x1 XSPC EX120 120mm, x1 XSPC EX360 120mm, x1 Hardware Labs Black Ice SR-1 240 120mm
- CPU Block: XSPC Raystorm CPU Waterblock (Intel)
- GFX Block: EK Water Blocks EK-FC7990 SE - Acetal
- Pump: XSPC D5 Vario Pump
- Reservoir: EK RES X3 250 Reservoir
- Fittings: XSPC Black Chrome Rotary & Compression fittings
- Fluid: Mayhems Ultra Pure H20 Fluid w/ Mayhems Orange Dye
- Fans: x6 Noiseblock Black Silent Pro PLPS 120mm Fans
Cost = £2764.00
I'm aware that both specs are good and I know it's not a completely fair comparison due to differences in hardware and price.
I like the first computer more in terms of hardware as it's simply more customized to want I want. However due to my disability I never thought I'd be able to have a water cooled system not being able to put a computer together myself.
So is the second computer worth it for the water cooling alone? I imagine it would be harder to upgrade in future due to the custom water cooling components.
I'm not sure how OCUK work if they'd be willing to customize it more if I sent them an email, I very much doubt they would though.
Please let me know your thoughts on which build you would go for. Also feel free to critique either spec.
Thank you for your time.
Regards,
Virgil
Computer I
OS - None
Cost = £4,838.00
OS - None
Cost = £2764.00
Regards,
Virgil
