What sort of a question is this on these forums!!! Hammer the dam chip man!!
Would I not be better to go for a Piledriver over a 1090T?
Keep an eye on your cpu usage compared to your gpu usage. If your cpu is maxed out and your gpu isn't, then no. If it's the other way around, then yes. Single card isn't that bad, but you would benefit from a nippier cpu alright.
yes deffo, because my rig is really slow with the OC removed, i've never noticed this before, because you only really notice it when you install a new Mobo, just before you've OC it all..
where will it end though !!! because if you start getting fussy about this, then it looks like your whole rig will need updating
 I put this down to my phenom 955, so I'm just not bothering overclocking it.yes deffo, because my rig is really slow with the OC removed, i've never noticed this before, because you only really notice it when you install a new Mobo, just before you've OC it all..
I overclocked mine to the max the sliders can do in CCC and found it made not an ounce of difference in the Unique vally benchmark, infact in one benchmark it was a frame slowerI put this down to my phenom 955, so I'm just not bothering overclocking it.
