Caporegime
- 9 Nov 2009
- Planet Earth
FX8320 is my choice too,especially as, IIRC, the cheaper AMD motherboards tend to support IOMMU more often.
K version has had VT-d disabled so non-K only.
This is the reason why the usual suspects don't get why some of us are aggressive to anti-FX posts as so many are blinded by brand bling and don't actually know what they are posting.
This thread summates it.
most people simply don't know what they're chatting most of the time (That goes for both vendors)
Why don't you consider a 4820K if VT-d is important? it's clocked higher than a 4770K at default and will leave an upgrade path in the future.
Best advice given so far.
OP wants to get 6+ years out of this build.
An X79 board with a 4820 and an upgrade to a 49xx chip a couple of years down the road.
Lots of memory slots for large amounts of RAM for running the VM's.
Plenty of PCIe lanes for multiple VC's if the OP needs more GPU compute power.
The OP's requirements over a 6 year period may well change and the X79 platform is the most flexible.
Initial costs will be slightly higher but this build is intended to be in service for 6+ years.
PS
Shame on those who recommended a 4770K as it is totally unsuited for use in a VM host machine.
FX chips are fine with lower memory speeds but if you are really pushing CPU or memory, four dimms is difficult to get going. Use to be worse on BDs though, they didn't like most things above 1600 when using all four dimms and generally had to be tweaked to get working at higher speeds.
Doesnt really make a difference as 1600/1866 is all you need.
My first 8320 came in the tin. I've still got it (the 8320 and the tin) and once I get a replacement Asrock board in I'm going to build it up for my lady![]()
