Really Weird Issue....
14 Sep 2008
Keeping 'er Country!
Hey Guys,
Pulling my hair out with this one. Since I moved back to uni, my pc has kept crashing, not just a standard lockup no...
But a crazy lines on screen freeze (image below). I've done the usual of taking the machine apart, clean, put back together, check all connections etc but it's still happening. Mainly when doing anything CPU intensive.
Any help would be greatly appreciated, it's killing me.
System specs:
AMD Phenom II x4
8GB DDR3
SSD
750w PSU
Sapphire HD 7850 GPU
Tried the bios reset, clear cmos etc and still the same. Nothing overclocked either, completely stock. Thanks for the replies guys!
what make/model ssd?
does it do that in the bios? and have you set the power control slider in ccc/overdrive settings to 20%? might help
Its an OCZ-Vertex 2 100gb and I'll try bumping that up, thanks
I can't recall it doing this in bios, only when running games or VMware
could be simple as the power control slider
mine craps out unless I set it to 10% some need full 20%,doesn't add any voltage just raises the thermal limit of the card
Just tried it at 20% and went to launch a VM and same result! Thanks for the suggestion though mate.
try xmp for your memory in the bios
and maybe try a touch more cpu northbridge voltage or a higher level loadline calibration
As soon as I try to load a VM. I've tried running each stick of ram individually and also taken out everything non-essential.
Anything useful in the windows event logs?
Might also be worth checking you've not accidentally disabled virtualisation whilst in your bios.
