- 29 Mar 2012
Hi all,
I'm looking for a little advice and hope someone can help.
I want to inject a little more graphical performance into my system without splashing out too much, so I'm thinking of trying to find a second hand GTX560ti 2048mb card for sli (to match my current card of course).
My CPU is an i7 2600k with an OCUK overclock (4.2 I think) and I believe the current card is also OC'd. (Is this an issue with SLI?)
It runs BF3 on Ultra at a good framerates but the BF4 beta was a little dissapointing graphically. So i want more power.
So instead of spending £200 on a new generation mid-range card, I want to try SLI.
Based on my CPU, do you think its's worth trying it? Will I see a significant performance boost? Second hand 2gb 560ti seem to go for around £80, but they are quite rare (stupidly went 2gb when not really needed when I bought the PC).
The PC is one of Overclocker's old BF3 commander packages and I made sure the PSU and MB were ok for SLI when I bought it.
If general consensus is that SLI isn't worth it, what kind of card am I looking at these days to run BF4 on high ultra. Can I do it for less than £200?
Thanks...
Thanks...
