Radiator fan options - Opinions please
Ah maybe swiftech have the same habbit as hwlabs then of sending 27mm long screws that won't go case> fan> rad.
Do you know what thread size you require?
Yeah, I had to buy longer screws when I did Rad -> Shroud -> Fan -> Case.
M3 50 or 55mm iirc, a pain to find!
No room for shroud in my Carbide now though.
I've just got the standard 30mm M3 screws. It's enough for the fans to case but need to a little further to screws in to the rad. ..
as above.. You might be slightly confused. The screw needs to go through the fan mount, then through case then into the rad so the rad effectively is the bolt. See diagram in option 1 post 1 ;) fan>case>rad
