Hi guys I'd appreciate any feedback on my conundrum.
I'm going to be buying a 4770K with a Z87X-OC to put in a 750D in the coming days, but I can't decide which cooler to get, both are in budget.
I will be overclocking the 4770k, but the looks of the build are important to me too.
I've narrowed it down to either a H100i or SB-E SE but cant make up my mind.
H100i
+ No ram clearance issues.
+ Looks better IMO.
+ Simpler mounting.
- Possible issues if it leaks.
- Cost.
SB-E SE
+ Cheaper
+ Less working parts/less to go wrong
+ Slightly better performance
- Weight
- While it looks good for an air cooler the h100i looks a lot "cleaner"
What do you think fellow OCUK'ers?
H100i
+ Looks better IMO.
+ Simpler mounting.
- Cost.
SB-E SE
+ Cheaper
- Weight
In most cases the cooler intake air temp changes (sometimes dramatically) under load.
