** BLUE OR GREEN? IN WIN H-FRAME MINI ITX **
rjk
rjk
OcUK Staff
8 Aug 2007
Hi Guys
Incoming from IN WIN we have the fantastic new Mini ITX H-Frame Chassis.
This is the pinnacle of small form factor design, Glass windows, PSU Included, everything you need to make a stylish, quirky and unique system is here!
In Win H Frame Mini, Mini-ITX Case - Silver / Blue @ £159.95 inc VAT
The Inwin H-Fame Mini has an Innovative H-Framework with stylish design. Its Open-air layered aluminum metal plate structure provides an excellent thermal performance chassis.
Features:-
- Portrait / Landscape Dual - Orientation Flexible Design
- Innovative H-Framework with R-Curve Design
- 1.6~2mm Laser-Cut Layered Aluminum Metal Plate Structure
- Fan-less Design
Specification:-
- Form Factor: Mini-ITX
- Material: Aluminum, Glass (removable end plate)
- Color: Silver & Blue
- Expansion slots: 1x Low Profile
Drives:
- 1x slim 5.25 inches (external, single-swap)
- 2 x 2.5 inch (internal, EZ-Swap)
I / O Panel:
- 2x USB 3.0
- 1x each Audio In / Out
Only £159.95 inc VAT.
ORDER NOW
In-Win H Frame Mini, Mini-ITX Case - Gray / Green @ £161.99 inc VAT
Features:-
- Fan-less Design
Specification:-
- Color: Grey, Green
Drives:
I / O Panel:
- 2x USB 3.0
- Preinstalled 180W 80 Plus Bronze Power Supply: AC Adapter
- Dimensions: 108 x 262 x 287 mm (W x H x D)
Only £161.99 inc VAT.
ORDER NOW
These look great but I doubt you would have any hardware worth showing off with a window if its being powered by a 180w PSU.
Silly me, I thought this was another competition, I read it as WIN an H-Frame Mini :o
you can win one of these if you like.
all you have to do is click the buy button.
pay us £161.99
and you will win your very own In Win H-Frame Mini :)
I'm guessing you can't fit a normal PSU in them, also no room for a normal sized dual slot graphics card.
Nope, but it seems to include a 180W PSU. Raw power at your disposal! Enough to power 2 lightbulbs!
The Inwin H-Fame Mini has an Innovative H-Framework with stylish design. Its Open-air layered aluminum metal plate structure provides an excellent thermal performance chassis. incl 180W psu
