7970 Matrix Plat. 3-Way Crossfire Motherboard?
22 Oct 2013
Hi,
Is there an (AMD Compatible) motherboard that would fit three 7970 Matrix Platinums in Crossfire? I've seen two of these cards in a Crosshair V Formula Z but even then it looked very tight with each card being 3 slots wide.
Any suggestions?
Thanks.
Cost of a formula-Z is quite high compare to many formidable haswell motherboards.
If i were you i would sell the 8350 and get a 4770k and 280x's instead because they can be had for cheaper and many feature the same base clock. You will also have more breathing room between the cards and i hear the Toxic cooler is no slouch! After a decent overclock, your bottleneck will be much lower.
