So why don't Sky cap their 20Mb upload? Your point is totally specious.Same reason a professional builder doesn't use consumer tools, you need a business account.
I suspect that I won't be the only one to be slightly aghast with incredulity that you could make such a fatuous statement. Please stop being an apologist for VirginMedia.
The service is for whatever you choose to legally do on the internet!
It goes to 65% (it used to be 75%) Your inaccuracies underline your lack of an informed response, and your understanding what is being talked about and what is really going on.
Upload on FTTC isn't such an issue because unlike DOCSIS it isn't a broadcast network shared between hundreds of premises.
Upload capacity on cable broadband is constrained because of the way the technology works - in most areas after VM have done their upgrade work they have 2x 20Mbit upstream channels shared between possibly a few hundred premises which is why they have to have fairly aggressive throttling if one customer can use almost a third of the capacity to themselves.
If you upload a lot cable broadband is not good - FTTC is a lot better suited.
in the SH2 settings I have one ip address in firewall logs and it keeps coming back when reboot the SH2. I don't know who/what it's for, how do I block a ip on a SH2?
What's the IP address?
Post a sample of the log.
Dear gareth
Thanks for your report.
The IP address is part of the virgin media infrasctructure and is responding to your superhub 2's DHCP requests.
Kind regards
J Arnold
Virgin Media
Remove your blu-tack and phone them again. Describe the problem exactly. Try not to get one of the useless offshore call centres.
I'd test the speed connected by cable to the SuperHub. Go to Speedtest.net and see what speeds you are getting. I would strongly advise you to call VM and tell them how bad the wifi on your SuperHub 1 is and insist as politely as possible that they send you out a SuperHub 2 free of charge.Ive got a VM super hub (30mb), macbook pro and mini mac, all affected for download/skype issues and airplay. iphone gets issues for airplay too. All devices are in the same room.
Any ideas?
cheers fellas.
Also download and run Inssider and make sure you are the only one in your vicinity that particular channel.
@kiteloopy Ask for a new VM SH?
