I've heard rumours of the level being floodable, trains controlled by signals so you can get Metro trains running through the level, the lifts actually working up to point B and perhaps even the area under B being collapsible using Levolution making it drop down to the bottom level. All rumour of course.
Really looking forward to this, I've been a bit 'lost' since the beta ended - can't seem to get into my other games without pining for BF4![]()
Well, less than a week to go before we will be VPN unlocking the game. I'm going to use the time to rebuild my PC and get my 780 on H2O. Have already warned the misses that I will be making a mess of the flat this weekend![]()
Can you unlock the volts on your 780? Can get 1.3v out of mine using afterburner trick and I'm tempted to go water as well but it's a right **** on.
I've not tried yet. With max power in afterburner at 1200Mhz it's getting really hot in BF3 and is unstable. I have the MSI Gaming addition so the cooler is good but even on 100% its not cool enough. Once I get the block on I'm going to try Greg's guide
Only thing that is bugging me is whether I need another 780 to run BF4 @ 120FPS constant.
So what you guys reckon could i run this at med/high?
My spec is
AMD X6 6300
8GB 1333Mhz Samsung
ATi 7770GHz Edition
I can run 3 in mostly high but then i was playing at a lower res this time im wanting to try it at 1920x1080 since i got a new monitor since BF3 but gut is telling me medium at best![]()
At 1080p that's going to struggle on any settings unless you play small 16 player maps.
Nah i need my full on 64 players like on bf3, getting a new graphics card isnt an option atm either as im getting the new consols![]()
