- 3 Jun 2009
- London
Mine is at 4GHz using 1.34v. Little beast of a CPU really. I was going to wait for Ivy Bridge, but might hold out until Haswell now.
750's are stunning overclockers. Mines rock solid at 4.1GHz and has been for well over a year now ...... Temperatures creep into the very low 80's with a long run of prime. I'm definitely waiting for Haswell or beyond for an upgrade.
Sounds like a very nice setup thereMy 24/7 overclock is 4.5Ghz core, 4.5Ghz cache. Normal gaming temps are in the high 40's/low 50's but that's with high end custom watercooling (spec in siggy) where both rads are mounted in a box on a windowsill sucking cooler air in from outside. Just played Crysis 2 for a couple of hours and my water temp is 19 degrees.
It will do 4.8Ghz but needs silly volts and temps approach 90 degrees when running Linx. never thought i would ever see temps like that with my cooling setup but Haswell is so hot running.
The best thing i have found with Haswell, apart from running my SSD at full speed now, is the memory overclocking. It was so easy to get all 4 sticks of my Sammy greens running at 2133mhz with tight 1st, 2nd and 3rd tier timings and only 1.5v. No other voltages touched at all!! It was a pig to get it to run at 2000mhz with a lot of fettling on P55.
