Why such a big PSU?
25 Nov 2009
I appreciate the more headroom your PSU has the easier life it has but what are you possibly doing with 1200W supplies!!!
I have an OC'd 2500k with a 7950, Corsair H100, 1SSD, 1HDD, 1OD and about 7 fans all running fine from a Corsair 550w PSU that has been going for 4 years now faultlessly. Shortly I'll be replacing the H100 with 18w of draw in the form an Ek 4.0 pump and I doubt I'll have any issues. Maybe 600w or so would be a more comfortable supply with this setup and if I were to crossfire the 7950 no doubt I'd be in the market for around 800w.The online calculators suggest I'm using around 300-350w
Just after your thoughts really, are we just going for much higher capacities than we need?
In general it's to do with energy efficiency. Most PSUs will operate at their best efficiency while under around 50% load. So if your system draws 500W, a 1000W PSU will provide the best energy efficiency.
My reason is that below a certain percent of power being used, the fan does not spin up. So in effect have a fanless psu and still have a high end system.
Also efficiency as mentioned above.
Not sure I agree with this statement but as NNNN points out, have you got any further info on this?
There's countless reviews and manufacturer specs out there.
>bashed Corsair into Google
>clicked products > power supplies > chose the first item
>scroll down
Being more specific, type "power supply load efficiency" into Google and read the first article from Anandtech
Yes 1200W is excessive. It's more about wanted the best, and knowing it will cope no matter what. Voltage spikes, fast power changes are all more easily coped with by a bigger power supply (in general), and obviously... the efficiency.
Totally agree a 1200 watt power supply is almost never needed though; You would have to be running an excessive setup for that.
The less load on a PSU normally means better efficiency. High wattage PSUs still only draw what they need.
Stelly
