- 11 Dec 2005
- Cheshire
In the run up to the launch of arguable the biggest game of 2013, here at OcUK we have released a range of Battlefield 4 Limited Edition systems. Designed form the ground up to be fully optimised for Battlefield 4. gear up soldier!
"Digital Illusions Air Strike" Intel Core i7 4770K @ 4.5GHz Overclocked Gaming PC ** With Free Copy of Battlefield 4 and four other free games ** @ £1994.99 inc VAT
** This system includes one copy of Battlefield 4 (to be provided upon launch) and one AMD Ruby Voucher code which can be redeemed for four free games **
The "Digital Illusions Air Strike" system is designed from the ground up to maximise the Battlefield 4 experience. Packing the latest 4th generation Intel Core i7 processor, the venerable 4770K, paired with the stellar Gigabyte Z87X-OC motherboard. Pushing the boundaries, the "Digital Illusions Air Strike" is overclocked to rapid 4.50GHz of quad core, hyperthreading power. Increasing the amount of processing power further to deliver absolutely outstanding gaming performance. Not one with time to pause, the " Digital Illusions Air Strike" is equipped with 16GB of 2133MHz DDR3, allowing for unparallel multitasking.
A Phanteks PH-TC14PE Cooler keeps the "Digital Illusions Air Strike" cool when under operation, whisking hot air away from the system with ruthless efficiency. The weapon of choice as standard is the brand new, deadly AMD HD R9 290X 4GB graphics card, chosen for its epic performance and massive 4GB VRAM, both essential for running Battlefield 4 in all its grandeur. To really turn the heat up you can upgrade Crossfire! Only hardcore gamers need apply.
Storage is handled by both a SSD & HDD, a Samsung 840 Evo Series 120GB is selected a primary drive enabled for record OS boot times with an optional second SSD configured for split second application and game load times. The Storage HDD is a Seagate Barracuda 2TB SATA III drive offering ample space for literally everything else.
The "Digital Illusions Air Strike" is finished off in a fitting Corsair Carbide 540 case in black. Decorated with Orange LED fans and accompanied by Orange Bitfenix Alchemy Modding cables and Orange LED strips for a genuinely unique system.
System Specification
- Case: Corsair Carbide 540 Cube Case
- Power Supply: Corsair Enthusiast Series TX 850W V2PSU
- CPU: Intel Core i7 4770K 3.50GHz @ 4.50GHz Quad Core Haswell CPU
- Motherboard: Gigabyte Z87X-OC (Socket 1150) ATX Motherboard
- RAM: 16GB Team Group Vulcan Orange 2133MHz Dual Channel Kit
- Hard Drive: Seagate Barracuda 2TB HDD
- Solid State Drive: Samsung 840 EVO Series 120GB SSD
- Graphics Card: AMD Radeon 290X 4GB GDDR5
- Sound: Realtek 7.1 Channel Sound (On-Board)
- Optical Drive: OcUK 24x DVD+/-RW SATA Drive
Why You Should Buy This System
- A guaranteed 4.50GHz performance for the price of 3.50GHz
- Cinematic DX11 graphics provided by AMD's latest R9 Chipset Cards
- Precision built and cabled by Overclockers UK expert technicians
- 8 Hours stressed tested and quality controlled
- New Corsair 540 Cube Case providing Dual-chamber Direct Airflow Path™ design for outstanding cooling
- USB3, SATA 6GB/s, Intel Ethernet for next gen computing
- Case: Corsair 540 Cube Case
- CPU: Intel Core i7 4770K 3.45GHz @ 4.50GHz Quad Core Haswell CPU
- Motherboard:Gigabyte Z87X-OC (Socket 1150) ATX Motherboard
- Hard Drive: Samsung 840 Evo 120GB (optional Primary and Secondary SSDl) with Seagate Barracuda 2TB HDD Storage
- Graphics Card: AMD R9 290X 4GB Gaming Series Graphics Card
- Sound: Realtek 7.1 HD Channel Sound (On-Board)
- Optical Drive: OcUK DVD+/-RW SATA Drive (optional)
Service Package
- Full 24 Month collect and return warranty
- Each specification is assembled from handpicked components for compatibility and stability
- Telephone, web note and forum technical support
Is this System for You?
Unique form factor with superb MSI gaming hardware appeals to the hard core gamer.
Note - If you would like to make a small change to the specification call our sales team on 0871 200 5052 and they will be happy to help.
* No OS systems are fully tested with the same extensive methods as systems chosen with an operating system. Including tests such as CPU, memory and GFX stress tests. All no OS systems are formatted completely before shipping.
*Please allow 7 working days for your system to be built and configured. This may take longer during busier periods.
*Fast track service subject to current stock levels during busier periods.
*Please note, unless specifically stated in the specification above, gaming systems are not shipped with "free games" intended for component promotions.
Only £1994.99 inc VAT.
ORDER NOW
"Digital Illusions Fire Support" Intel Core i5 4670K @ 4.2GHz Overclocked Gaming PC ** With Free Copy of Battlefield 4 and four other free games ** @ £1172.95 inc VAT
The "Digital Illusions Fire Support" system is designed from the ground up to maximise the Battlefield 4 experience. Packing the latest 4th generation Intel Core i5 processor, the exceptional 4670K, paired with the stellar Gigabyte Z87X-OC motherboard. Pushing the boundaries, the "Digital Illusions Air Strike" is overclocked to 4.20GHz of quad core power. Increasing the amount of processing power further to deliver absolutely outstanding gaming performance. Not one with time to pause, the " Digital Illusions Fire Support" is equipped with 8GB of 2133MHz DDR3, allowing for unparallel multitasking.
A Prolimatech Megahalems Cooler keeps the "Digital Illusions Fire Support" cool when under operation, whisking hot air away from the system with ruthless efficiency. The weapon of choice as standard is the brand new, lethal AMD HD R9 280X 3GB graphics card, chosen for its fantastic performance and hefty 3GB VRAM, both essential for running Battlefield 4 in all its grandeur.
Storage is handled by both a SSD & HDD, a Samsung 840 Evo Series 120GB is selected a primary drive enabled for record OS boot times, split second application and game load times. The Storage HDD is a Seagate Barracuda 2TB SATA III drive offering ample space for literally everything else.
The crowning glory of the "Digital Illusions Fire Support" is a truly unique laser etched BitFenix Shinobi case. Designed in conjunction with & fully licensed by DICE, EA and AMD Europe the case is professionally etched creating an impressive ghostly effect. Finished off with orange logo and mesh stripes for a genuinely unique system.
- A guaranteed 4.20GHz performance for the price of 3.40GHz
- Case: BitFenix Shinobi with Orange accents and laser etched side panel
- Power Supply: Corsair Gamer Series 600W PSU
- CPU: Intel Core i5 4670K 3.4GHz @ 4.2GHz Quad Core Haswell CPU
- RAM: 8GB Team Group Vulcan Orange 2133MHz Dual Channel Kit
- Graphics Card: AMD R9 280X 3GB Gaming Series Graphics Card
Service Package
Only £1172.95 inc VAT.
ORDER NOW
"Digital Illusions Semper Fi" AMD FX-8 8350 @ 4.4GHz Overclocked Gaming PC ** With Free Copy of Battlefield 4 and four other free games ** @ £1045.00 inc VAT
The "Digital Illusions Semper Fi" system is designed from the ground up to maximise the Battlefield 4 experience. Packing a whopping 8 cores of 4.4GHz AMD processing power, paired with the stellar Gigabyte 990FXA-UD3. Pushing the boundaries, the "Digital Illusions Semper Fi" is overclocked to 4.40GHz, increasing the amount of processing power further to deliver absolutely outstanding gaming performance. Not one with time to pause, the "Digital Illusions Semper Fi" is equipped with 8GB of 1600MHz DDR3, allowing for unparallel multitasking.
A Zalman LQ315 Liquid Cooler keeps the "Digital Illusions Semper Fi" cool when under operation, whisking hot air away from the system with ruthless efficiency. The weapon of choice as standard is the brand new, lethal AMD HD R9 280X 3GB graphics card, chosen for its fantastic performance and hefty 3GB VRAM, both essential for running Battlefield 4 in all its grandeur.
- A guaranteed 4.40GHz performance for the price of 4.0GHz
- Unique laser etched case licensed by DICE, EA and AMD
- CPU: AMD FX-8 8350 @ 4.4GHz Eight Core Haswell CPU
- RAM: 8GB Team Group Vulcan Orange 1600MHz Dual Channel Kit
Service Package
Only £1045.00 inc VAT.
ORDER NOW
Service Package
ORDER NOW
Service Package
ORDER NOW
Service Package
ORDER NOW
