You need to turn the volume up a bit!
Found a R9 290X at £388.28 inc VAT with shipping. Say whatever you want, but at this price, its very tempting even with R9 290 around the corner!
Noise cancelling, maybe.now that IS tempting..could afford an aftermarket cooler too at that price
but where i wonder![]()
Now imagine that kind of discount on the R9 290...AMD truly best bang for your buck.
Nc headphones just about cut out the noise of highly oc'd gtx 470's for me. Quite possibly one of the loudest and hottest running series of cards in recent years.Closed headphones can't save you from these buggersNoise cancelling, maybe.
Second pic shows the temp at 100degC for the beginning? Or am I going mad?
.Adding all of the FPS from each column and averaging them, gives 100.8 for the 780 and 103.8 for the 290X. That's a piddly 3% difference which can probably be made up quite easily by the 780's superior overclocking headroom, aided by it's better cooling.
The 290X wins by clock speed rather than architecture and potential, in the same way that the 680 beat the 7970 at stock clocks. The real differece between the cards is the cost, which NVidia could fix by knocking £50 off.
The 290X hasn't quite hit the spot where I would hit the buy button. Same for the 780.
The difference as a whole is much larger between the 780 and 290X....
As it should be,the 780s been around for a while now
And?? What's your point?
