- 28 Mar 2012
- UK
Hi guys,
I will be installing my first watercooling kit soon, the kit is the EK L120. Just a cpu block but its perfect for price and what I want atm.
I have a question for you guys.
I have a Corsair 800d case and it has a removal motherboard backplate, so you can mount coolers without removing the motherboard.
Does this apply to watercooling? Or will I have to remove the motherboard? And is it 'better' if I did?
Just curious. Neither is a problem, I just dont want to take the motherboard out completely if there is no need!
Thanks,
Ben
Thanks,
Ben
) , motherboard, res, pump and psu. Then I fit the tubing using compression fittings (personal choice).
